I was under the impression that structural battery pack design and implementation was being set up in Giga Texas and Berlin. Elon said it was a priority to get MY production started in those factories, and the recent media/social releases around both front and rear casting as well as structural designs would mean that at the very least in 2022 MY's coming from either of those two factories will have two of the three big improvements that were alluded to.
1. Front and Rear Castings in 2022 MY's
2. Structural Battery pack in 2022 MY's
3. 4680 Batteries included in 2022 MY's
My inclination is that even if 4680 isnt ready for prime-time, the assembly lines are being created so that Point 1 and 2 are standard manufacturing tooling processes. It makes no sense for them to build these factories where they would have to switch tooling assemblies and shut down so that they can later implement the new castings or structural battery pack.
They showed that 2170's could be put into the structural battery pack in the event that 4680's were not ready.
So that being said. I think its more than likely that on the conservative side, Q1 MY's produced in Austin will have both structural battery packs and front and rear castings, but likely no 4680's.
From the photos of packs and company descriptions, it does not appear that 2170 battery packs are structural. Consequently, chassis assembly will be slightly different for each.
That said, the difference will be relatively minor and robots included/excluded from the line. This can be accomodated easily in Austin / Berlin (space available). Not so much Fremont.
Specifically, the chassis for non-structural battery packs requires a floor panel. This was explained in Berlin.
The structural pack IS the floor panel. So this is two positions in the assembly line, one for each. Skip one or the other depending on the chassis build.
The second change is more challenging. Robots currently install seating AFTER chassis assembly, as a separate operation. With a structural pack, the seating is PART OF that pack.
So again, you've got two different robot assembly cells, plus two different seating assembly cells.
It all sounds simple but it's NOT.
Both Austin and Berlin were designed with the assumption that 4680 batteries would be forthcoming.
Well, it's been over a YEAR since 'battery day' and they ain't 'soup' yet.
Witness the Austin factory - steel for the cathode plant was delivered a month ago. It's still sitting on the ground. No need until battery processes are good to go.
Tesla will not introduce a '2022 MY' until 4680 batteries are manufacturable at scale.
Until then, a "v1.5" will be delivered, using non-structural 2170 packs. That plan is clearly evident.
But even these will weigh approx 200lbs less than the current MY v1.0, by using front + rear megacasts to increase assembly speed and decrease weight (reduced steel content).
I'm personally good with a 2170-based MY v1.5 as I don't think 4680 'engineering issues' will be solved with the necessary factory equipment changes, until maybe Q2 2022 at best.
I don't do road trips, and that's the situation where 4680 batteries will make a difference. Charging time. It matters then. But not for daily driving out to 200 miles round trip.
BTW, there are stacks and stacks of castings sitting in the lots at Fremont. Look at the drone footage available.
What this means is that Fremont is not yet building MY v1.5 - the castings piles are growing, not shrinking.
Tesla has tremendous incentive to reduce costs and increase production volume. The v1.5 build is the way it will get done in the near term.
