Garlan Garner
Banned
I wouldn't care if it were a 10K battery....so long as I could get 220 miles.
You are exactly right.To be clear, it was reported that he said "just over 50 kWh". Not sure why people are interpreting that as "= 50 kWh".
Regardless, it's the 220 mile number that matters more than the number of kWh's.
I had hoped they'd match or beat the Bolt's 238 miles, and I think the $9k is a bit steep for the upgrade. So, yeah, I'm a bit disappointed. But they didn't miss their original 215+ mile range or $35k base price targets/promises, so I can't complain too much.
EVs always get better city mileage than highway mileage, regardless of air drag, because of regen.
As long as you don't include Teslas in that 'always'. e.g. Model S P100D 92 city 105 highway.
Thank you kindly
It is only recommended not to let your batteries sit at 100% for long periods, there is nothing wrong with charging to 100% and driving fairly soon after it is done charging.Considering:
1- it's recommended you only charge the batterie for 85-90 % to increase life
The range is based on the EPA test cycles which use a mix of high (highway) and low (city) speed driving.4- 220miles based on a lot of highway driving and taking advantage of the m3 good C.O of 23 which is less effective in city driving.
If you have that much range anxiety, perhaps you shouldn't be driving with such a heavy foot.5-220miles based on not having a heavy foot and always only gradually getting up to speed.
6- -20 to 30 miles to save you range anxiety.
From what I understand, someone correct me where I go wrong, cold weather range loss is from two main things, running the heater, which you already mentioned and from the battery not being warmed up. You can alleviate that by preconditioning the battery before driving. In fact, from point number 1, charge to 100% right before you leave and the battery will be all warmed up for you, you can even preheat the interior while it's plugged in and save running the heater that much more.7 - cold weather range loss
Improper upkeep of your car is your own problem.8 - tyres not pumped up to optimal pressure
From everything I've read most people experience a drop of 2% - 4% over the first year or two, not the first two months.9 - 1 off 5 miles loss from max new range after a month or 2
If range is your primary concern then perhaps the model 3 isn't the car for you. No car is right for everyone, if this one really won't do it for you, or you have that much range anxiety, then either get the larger battery, a different car, or wait for one the meets your needs.I'm a bit disappointed that tesla can not beat the 60kwh Gm bolt which is probably much superior in the city and much cheaper after there $5000 haggling discount.
We were promised a 200+ mile range base model for US$35k.. thats what Tesla is delivering (eventually). What is there to be disappointed about? It was never going to do 200miles up a mountain in a blizzard with a horse trailer on the back.
I'm not disappointed in the range.
Happy about the efficiency.
But a bit disappointed in the battery capacity, because of the effective loss of capacity that I'd see in winter.
Nope, it is based on the EPA testing procedures.
What is a C.O? and 23?
Why wouldn't you keep your ti(y)res properly inflated?
Thank you kindly.
