I'll use my heater in addition to seat heater in the winter thank you very much. I am not going to dress like an eskimo to stay warm IN MY CAR! Do you people not use heat in your home as well and just "dress for the weather"? lol
It is actually pretty funny to imagine people sitting in the cold with one of the most advanced cars in the world. I still have fewer than 500 miles on mine so still learning and experimenting with its efficiency limits. I'm sure once I'm passed this phase I'd have the climate control always on like in any other car.
If you have a reasonable commute just leave it in Auto and plug in every night. You're electricity cost will only go up a cent or two per mile. It is also amazing how many owners of a $60 K car don't have garages up north. I lived up north for 42 years and would never dream of having a dwelling without an attached garage ( or of living in a city ). Your results may vary.
Y
HVAC Auto stinks.
I have been playing around with settings a lot, this is what I came up with.
Manual Mode:
A/C: Off
Window Blower: Off
Front Blower: On
Floor Blower: On
Recirculate: On
Fan: Usually 3-5
This runs real good energy wise. BUT if you have to many passengers OR it's too cold you WILL fog up.
If you fog up (Blast for a Minute with Defrost HIGH) then turn on A/C to maintain.
Turning on A/C to keep humidity down costs juice but not as much as heating outside air (Recirculate Off).
If you still can't prevent fogging then you have to turn Recirculate Off and at that point you can turn A/C off too (don't try to dehumidify outside air). And you might have to turn Window Blower on too to maintain (to warm windshield and evaporate the fog). But that will use a lot of juice when it's cold (but you may have no choice).
It depends on outside temperature, dew point and how much humidity you are generating in the car what settings you can get away with.
The key is, if you can run with Recirculate ON you save a ton of heat.
And you often can. I got 250 wh/mi (on my short commute, which is worst case) with first set of settings above and it didn't fog up.
But it wasn't extremely cold today (but I did need heat). Only one mammal.
If I leave Window Blower: On it will sometimes fog up faster blowing humid air (from humans and other mammals) onto the cold windshield.
If I was in Auto it would have been 350 wh/mi or more.
Also it's not just about cost per mile, it's also range, how many stops you need to make and making it to your next charge point.
Heat makes a HUGE difference and how you manage it can make a huge difference too.
P.S. I personally don't like seat heaters in place of cabin heat. But if you don't mind go for it and turn cabin heat down.
At 232 mph the heating load would add 4600/232 Wh/mile.For 200Wh/mile you would be have to be going about 23mph.
It makes for an interesting question how to minimize winter Wh/mile since faster speeds increase aero losses per mile while reducing heating losses per mile.
That's the speed at which you travel back in time. 88 mph is only in the movies.And what is the purpose of talking about 232mph?
I've only managed to go forward in time. Must be doing something wrong.That's the speed at which you travel back in time. 88 mph is only in the movies.
I try to run without heat when I do my long work drive. Once or twice I week I have to drive 230 miles (AWD 19") before I reach a charger. I run the heat up hot (78%) for about 30 minutes before leaving to be sure it is warm enough, and have the battery charged to 100%. When I leave I cut the heat and just use the seat warmer and drive no faster than 70MPH. Can do it with about 10% left when I arrive at the next charger. When I got the car and had to use the AC, just charging to 100 and limiting speed to 75 was enough to make it.
But, when Tesla puts their promised supercharger (was listed as coming in 2018, but hopefully they get it done in 2019) along the route I will no longer do all that, but will just charge to 90% and crank the heat and enjoy it like the luxury car it is supposed to be!
He said it was AWD/19s yes and he also said he turned the heat off in order to get that.Do you have the AWD 19" Long Range? That doesn't seem right that you can only go 230 miles (starting at 100% and ending with 10%). Does the heat use that much?!?
I have an meter on the circuit feeding my Tesla Wall Connector (set to 48 amp on 60 amp circuit).The HVAC system running flat out is something like 8-10kW in the Model S, that's with full heater plus AC drying the air. That's roughly what the Model 3 is, too, although I have only seen approximations so far and accounting for how motor unit is [assumed to be] used for bringing up the battery pack heat makes it kinda tricky to separate out the HVAC and everything. But that's not what get used outside of the first part of your trip unless you're in an extreme situation.
Once your cabin reaches steady-state it can cut back quite a bit, it just has to replenish what the vehicle loses minus what the occupants generate, plus manage the moisture the occupants generate (primarily via their breath). That is partially influenced by how fast you're traveling as air passing over will draw heat off the outside of the vehicle faster. So even though time and outside temp are the prime factors, that increased heat loss rate will partially offset the speed and traveling at 2hrs at 80mph versus 2hrs at 30mph won't be the same.
The most I have seen the heater pull (with no charging going on) is around 6.5 kW.
I see similar, if not less, range with the Performance version on 20s at those speeds and that distance. With heat on, there's no way I could make 230 miles.
Yea, I agree. I keep it 80F in my house in the winter so I can walk around in shorts and t-shirt, so yes you better believe I use the heater in the car on "HI" all the time. Weird thing I noticed that unless the heater is on "HI", only lukewarm air, which is kind of on the cold side, comes out even when set to 80F. So the only way to get medium heat is to set to "HI" and keep the fan on the lowest setting but I bet that uses a lot of energy which I am fine with. If you can't have comfort then what's the point of a 75K car.I'll use my heater in addition to seat heater in the winter thank you very much. I am not going to dress like an eskimo to stay warm IN MY CAR! Do you people not use heat in your home as well and just "dress for the weather"? lol
