I was looking at my menus this morning and mine are exactly the same as yours.Can’t speak to Sentry or key labels, but I just hopped in the car and noticed the following. I’m assuming it’s not just my car being weird:
- Automatic navigation turned itself back on (that feature that will navigate to home, work, etc based on where it thinks you’re going). Annoying.
- “Format USB” button was disabled for me. I don’t know if that’s because it is partitioned for music and Sentry already.
- Security Alarm and Tilt/Intrusion are enabled and greyed out (so you can’t disable them) whether Sentry mode is on or not. Previously disabling Sentry would allow you to change these two settings.
- Cabin Overheat Protection can be turned on and off regardless of the status of Sentry, Tilt/Intrusion etc. The tooltip says it can’t be enabled with Tilt/Intrusion on, but I’m assuming that’s now obsolete. It still says it only works for 12 hours after car last driven.
I rebooted the car thinking maybe my settings were messed up, but I got the same results.
Just like your photo, my Cabin Overheat Protection was auto set to ON after update. I was unaware it’s been running this morning, until I heard the fans running!Can’t speak to Sentry or key labels, but I just hopped in the car and noticed the following. I’m assuming it’s not just my car being weird:
Are you thinking of exFAT? The car has never supported EXT4 as far as I'm aware.
The popup for "Format USB" says it will format it as exFAT, so I presume it works now.
My app told me there was an update when I woke upDownloading now - i always have to go in the car to get it to check for updates
