You don’t get cameras though. That’ll be another couple hundred extra.
The cars already have cameras that work, they just don't have as good of color as the newer ones. So they aren't necessary.
^^In cases like those, you do a 2-button reboot (in park, hold both steering wheel buttons down while applying the brake till it reboots - wait for Tesla logo).
2) If it goes for awhile without seeing a sign and it becomes "unsure" (my word) of the speed (or it checks against the GPS database, I don't know), it just deletes the speed limit indication on the LEFT side altogether. Then it waits for a speed limit sign it can read before displaying the speed limit again. In other words, no more GPS-informed speed limit if it is relying on the signs
In my opinion #1 is a good thing, not a limitation. I'd prefer for it only to respond to actual official speed limit signs. We have the signs with the town limit for unmarked roads all over and they are almost always on a roads with a faster speed limit. I wouldn't want it slowing down for those.A couple observations from this morning's driving that I welcome confirmation on:
1) It really only recognizes "vanilla" SPEED LIMIT signs, i.e., signs that are rectangular and white w/black lettering (USA standard). It ignores any sign that has extra text (my town has signs that say TOWN SPEED LIMIT in the correct color layout) as well as yellow advisory speed signs. I suppose this could make sense to simplify the NN training to just one sign type, but definitely limiting the functionality.
2) If it goes for awhile without seeing a sign and it becomes "unsure" (my word) of the speed (or it checks against the GPS database, I don't know), it just deletes the speed limit indication on the LEFT side altogether. Then it waits for a speed limit sign it can read before displaying the speed limit again. In other words, no more GPS-informed speed limit if it is relying on the signs.
Nope, the sign I posted earlier is typically located on all roads that cross over the town border, and all roads at the bottom of a highway exit ramp. The 25 mph speed listed is almost never the actual speed limit on those roads. It's more of a "hey welcome to our town if you wind up on a street without a sign the speed limit is 25"Obviously I don’t know about roads in MA, but this wouldn’t be an unmarked road if it had a speed limit sign. I’m pretty sure my town law enforcement wants me to slow down for the town signs.
We found it ignored speed limit signs on curves. When we tested it on a road with nearly 90 degree turns and a 15 MPH speed limit, it didn't slow down at all and crossed over the double yellow line. It used to handle that location perfectly, slowing way down to handle the curves.In my opinion #1 is a good thing, not a limitation. I'd prefer for it only to respond to actual official speed limit signs. We have the signs with the town limit for unmarked roads all over and they are almost always on a roads with a faster speed limit. I wouldn't want it slowing down for those.
I think this is a separate issue. I thought it was using it's knowledge of the curvature of the road when it slowed down for curves, not the suggested speed limit warnings. I'd see if they fix that behavior in the upcoming 36.X revisions.We found it ignored speed limit signs on curves. When we tested it on a road with nearly 90 degree turns and a 15 MPH speed limit, it didn't slow down at all and crossed over the double yellow line. It used to handle that location perfectly, slowing way down to handle the curves.
2020.36 -
- Increased the response time to driver infotainment and other some other features. Adjust your volume while driving with the steering wheel to measure it, but many functions have increased lag.
- Seems to have reduced phantom braking. Based on situations and locations I've encountered PB in the past, they are so far (for me) eliminated.
- They broke the Next Song / Previous Song steering wheel function when playing USB sticks. Note that exFAT now works for TeslaCam, but you still have to have a unique partition for music.
They are probably going to patch it quickly. The lag affects some safety related items as well.
Upon further testing, I have to amend this statement. It did recognize TOWN SPEED LIMIT signs and showed them as just SPEED LIMIT signs in the visualization, so I have to assume it would have changed speeds accordingly. I wasn’t able to actually test a speed change as I passed three of the same sign on the same road in my town, and no other speed was indicated in between.1) It really only recognizes "vanilla" SPEED LIMIT signs, i.e., signs that are rectangular and white w/black lettering (USA standard). It ignores any sign that has extra text (my town has signs that say TOWN SPEED LIMIT in the correct color layout)
If the nav database (db) speed limit is different than the actual speed limit signs then you can just turn AP off and back on again to get the nav db speed limit ... when it sees the next sign it would adjust. I have a road near my house that is 40 but the nav db thinks it is 45. Thus with my +5 offset I can go 50 there until it sees the 40 mph speed limit physical sign and then it drops down to 45 mph IIRC.... I wasn’t able to actually test a speed change as I passed three of the same sign on the same road in my town, and no other speed was indicated in between.
MIGHT be coincidence but mine changed from 65 to 70 right at the sign today.
Plus it seems to move OUT of the passing lane again, albeit inconsistently. If there is a car behind you especially. And in one case of an impatient driver drafting me, it turned on the right signal before even clearing the semi.
2020.36 -
Here in Massachusetts we have these speed limit signs that say "speed limit 25 citywide - unless otherwise posted".
Typically they are mounted on major roads close after you cross a town line or come off a highway. More often than not they are on roads where the speed limit is in fact otherwise noted with a higher limit.
I was pleasantly surprised that the speed limit detection properly ignored these signs whenever I went by one.
and yes, it did pick up all of the normal speed limit signs that I went by.
So you have Speed Limit Sign Recognition & Green Light Chime Feature on a Model S with HW3 and MCU1and not a MCU2 ?
