I hit an object on the road which broke through the front skid plate and ripped away the battery coolant hose from the battery case.
Towed it in to service center after getting low coolant message and they are saying entire battery pack has to be replaced.
The estimate that they sent me lists the replacement battery pack as “ASY,HVBAT,75KWH,AWD-RWD,1PH,M3,RMN(1137375-01-W).
Does anyone know why the part number is listed as a 75kwh pack? My impression was that my car had the newer 82kwh pack in it. When I discussed it with the service advisor they just keep saying that my car had a 74kwh battery and that is what they are replacing it with.
Everything I can find on the internet points to the 2022 Model 3 LR as having Panasonic 2170L 82kwh.
Not sure what I should do as the service center just keeps going in a loop that my battery was a “74kwh” pack and that is what they are putting back in.
Service advisor tells me there has been no iteration of Model 3 with a 82kwh pack.
