It's 3 hours, not 5. And they have to be, well, continuous (on for 2, off for 1, on for 2, off for 1, on for 2 doesn't meet the definition).
Few, if any, home loads (other than EV charging) are really continuous. For example, heating appliances typically cycle on and off via a thermostat, even if they are turned on for hours. Roasting a Thanksgiving turkey for 4-5 hours in an electric oven isn't a continuous load. Unless you use the self-cleaning cycle, then maybe. But you won't have much left for Thanksgiving dinner.
NEC 100.1, Definitions - "Continuous Load. A load where the maximum current is expected to continue for 3 hours or more."
Also, 625.21 specifies that EV charging is always considered a continuous load, regardless of duration.
Careful here, you absolutely, positively, cannot wire AL directly to the HPWC. The terminals are Cu only. You can run Al to an Al-rated subpanel, disconnect, or spice (like a Polaris-style connector), then Cu to the HPWC.
