eJonny
They've been know to remove feature commitments through software "upgrades".
Such as?
When I put my P90DL in sport mode, my battery dropped from 395 to 332 volts at 1160 amps (385 Kw) at full power. The 352.8 volt battery would have to supply 1390 amps to provide the same power. This assumes it has the same internal resistance of 63V / 1160A = 0.054Ohms as a 90 Kwh battery. It should since it has the same number of cells in parallel.Under WOT, my S85 pack voltage drops ~80 volts and maintains 1000 amps battery current. Just for the S75 to *match* the maximum power of my S85 it would need to pull 1200 amps assuming the same voltage drop. But of course, the current is higher so the voltage drop will be even greater.
In order to shave 1 s off, Tesla will likely need to source >1300 amps, which means these packs will likely all have ludicrous fuses.
Don't want to hijack this thread, but see counter gate threadSuch as?
I have a version 3 p90dl pack with the lower resistance, and used my actual measurements to get an equivalent current for a 75Kwh pack.My guess is that the current 75kWh packs are using the newer module design from the 100kWh packs that have lower internal resistance. (Even the newer 90kWh packs have lower IR than the older ones.)
You are forgetting that they redesigned the packs so there is a less voltage drop now. So maybe under the 1000 amp load the new 75kWh packs will sag to about the same level that your 85 kWh pack does. As well the DU have been changed and may be more efficient, so they don't need to draw as many amps to get the same level of performance.
Oh, I see. Can we attribute this effect to something more concrete than just "new chemistry"?
Yes. There was less voltage sag at 1500 amps with v3 than there was with the earlier packs.I wasn't aware that the new chemistry improved the voltage drop by that much. That would be quite a feat to squeeze out more efficiency from the motor (mine is 92-93% efficient under WOT). Really eager to see the first hard stats for this new motor.
Did the resistance of the packs decrease with revision number? Meaning is a V3 pack lower than a V1 90 kWh?
I haven't had time to read all 19 pages of this thread, so i apologize if this is repetitive. I spoke with "Jesse" today from Tesla support who informed me that the 60D that i purchased nearly exactly a year ago, (HW1 of course) and which I upgraded to 75D a few months ago after the price drop, will indeed receive a software package that increase 0-60 to 4.2 sec. I remain VERY skeptical that this is true--but it will be AWESOME if it is true. He said this only applied to "D" cars and is included in software version 17.26.17. Time will tell.
17.26.17 has been out since 6/30...I haven't had time to read all 19 pages of this thread, so i apologize if this is repetitive. I spoke with "Jesse" today from Tesla support who informed me that the 60D that i purchased nearly exactly a year ago, (HW1 of course) and which I upgraded to 75D a few months ago after the price drop, will indeed receive a software package that increase 0-60 to 4.2 sec. I remain VERY skeptical that this is true--but it will be AWESOME if it is true. He said this only applied to "D" cars and is included in software version 17.26.17. Time will tell.
