I'm not caught up with the thread yet so apologies if this is redundant:No one has stepped up yet with a solution to my problem.
I've addressed that suggestion before, but unfortunately the solution/suggestion fails because it does not allow for moderated maintenance. Just as in software development, it's a really bad idea to allow open and unfettered modifications to a FAQ post that includes key safety information.
The blog post suggestion is covered above, as well - it does not show up in searches, and it actually makes the "find the information" problem even worse than it already is.
I feel as if I'm being told to "shut up, peasant", because it seems no one will respond to my varied attempts to communicate on real solutions. The responses are short and terse without an attempt to understand the problem.
Last night I implemented a solution that should give contributing members like the ones mentioned the ability to continue to edit the first post in their threads. Normally I like to verify software changes on a test server for a few days. That didn't happen here, so fingers crossed.
Thanks for doing that. How does one know he's on the list / how does one get on the list?
Excellent, doug. Much appreciated.Last night I implemented a solution that should give contributing members like the ones mentioned the ability to continue to edit the first post in their threads. Normally I like to verify software changes on a test server for a few days. That didn't happen here, so fingers crossed.
I used the Supporting Member usergroup, of which those mentioned are already part.Thanks for doing that. How does one know he's on the list / how does one get on the list?
I apologize for coming to this a little late but thanks Auzie for stopping to to think about how editing/deleting affects others. I'm absolutely sure that if we polled members and asked "Should every member be able to delete or edit posts you've already replied to?" The answer would be a clear "No"; it messes up historical conversations and has the potential to make many discussions look nonsensical. I'll admit that in the moderator past-life I supported the move to reduce editing abilities for that very reason, and I still do.
Could you please explain what is the problem with deleting a post, especially for example something that has errors or wrong information. Would that not be better than letting misinformation set out there permanently for someone to stumble upon? How is anyone confused by deletion of posts--please provide some detailed explanation because it is not obvious to me.
i'm a technical guy and don't do a bunch of chit chat nor do i have or want to have 11k posts out there. i don't post often but when i do i want it to be the best technical information i have or can find at the time. If it turns out the information was in error then it needs to be edited or deleted so as to keep the integrity and signal-to-noise ratio high.
I don't see the harm really . People will post what it was about if it gets confusing.It's the people that have gone back and deleted dozens or hundreds of posts in anger that cause a lot of problems. If there is an old post you really need changed or deleted simply report the post yourself and in comments say what you want done.
Now you have to pay for your freedom.
You can disrupt things quite badly. Just yesterday I saw a case where someone deleted a post and then the comments on that post (that happened not to quote it) that were following seemed very nonsensical.I don't see the harm really . People will post what it was about if it gets confusing.
That seems a bit harsh. I think my freedom is not defined by whether I can edit older posts of mine...Now you have to pay for your freedom.
