B
banned-66611
Guest
If it is not intended to be used on this road, Tesla should lock out AP.
That is in fact what both Cadillac and the new Nissan hands-free ProPilot do. Very sensible.
Should they also lock out putting the car in drive if your seatbelt isn't on?
How about locking out driving any speed above the speed limit?
It's totally relevant.
Requiring seat belts would save massively more lives than your idea. Yet you seem to not be in favor of it...for...some...reason....
If you can't understand 2 or 3 sentences in the manual you probably
Which would be a mere inconvenience...Actually, an even greater one- the car ALWAYS knows if your seatbelt is on. It can't be SURE if you're on an AP appropriate road or not because sometimes the maps are wrong.
In the EU the warning beeps if you don't have your seatbelt on are mandatory and cannot be turned off.
Autopilot does in fact limit the speed you can set, I think it's the speed limit +10% or something.
you are missing the point. I’m not the one saying people who drive without their seatbelts deserves to die.
should listen to Tesla’s marketing wank...
Cigarette companies can’t be held responsible for your cancer, after all.
Dude... YOU are the one who claimed it wasn't "clear" when AP was intended to be used.
I had to, once again, correct your factually wrong claim by citing documented proof.
I like how you glossed over getting caught saying the reason they don't lock out driving without wearing a belt or when speeding is it'd require adding costly hardware....neither of which is at all true.
it is not clear because of Tesla’s marketing wank.
because your statement was addressing what I was saying at all.
You asked why they don’t put speed limiters and interlocks in cars. The cost of adding interlocks to every car that has a seatbelt is high.
Given Tesla spend $0.00 on marketing you again appear to be just saying random nonsense words with no bearing on the topic.
All needed HW is already in the car. It'd require adding about 5 lines of code to the software. That's it.
No, just all new cars. Unless you have a good reason to exclude... Kia’s from the seatbelt lockout and autopilot lockout requirements? If we are going to require all new cars that have seatbelts to have interlocks, that will be expensive. If we require all new cars that will have self driving features to lockout areas where they aren’t allowed, the cost is low (Tesla actually does this already l)Or are you so desperate to avoid being wrong at every turn you're now moving the goalposts to be "safety in 30 year old cars that don't ALREADY know if your seat belt is on or not" instead of in a Tesla?
lol... naive. You don’t have to spend money on marketing to market your *sugar*, bro..
Citation needed. You actually only need one line of code. Putting code on lines makes it easier for the coder to read what he has written, the compiler doesn’t care.
Model 3 owners manual page 85 said:Autosteer is intended for use only by a fully
attentive driver on freeways and highways
where access is limited by entry and exit ramps.
qdeathstar said:WHY IS TESLA SO UNCLEAR AND CONFUSING ON WHERE I AM SUPPOSED TO USE IT
Please- by all means, quote some of this "marketing" from Tesla that contradicts the owners manual you apparently can't figure out how to read.
Because so far it sounds again like you're rambling on with utter nonsense unconnected to reality.
So programming would be yet another thing you don't know anything about
So again this lockout would cost zero dollars to add to the same cars you want AP lockouts on.
Because you just told us all new cars already detect this
Or to sum up...
Hey, what we need here is some deeper rectal probing, rather than merely skating the socratic surface.
So, Gentlemen, who's in favor of legislating greater citizen safety, beginning with some solid gun and knife controls? And smart Tylenol dispensers, to limit daily intake to 4 grams or less?
Oh, yes, I forgot:
the webpage the car is sold at listed fsd on city streets by the end of last year, and Elon said we would be able to drive coast to coast with no intervention.
still waiting for those ones... that is over marketing AP, in my opinion.
Get you some facts... compiler doesn’t care about lines. Only syntax.
You logic was that requiring a lockout on AP was the same as requiring a lockout in seatbelts. If that is true, if I want cars that have AP to have lockouts, I should also want all cars that have seatbelts to have lockouts as well.
that was your logic. Now for some reason you want to change it to Tesla’s only.
detecting is different than locking out ignition systems.
Sure they could, but Why would they? People should be smart enough to realize when and when not to use it outside of Tesla’s recommended areas. I have no problems in using it on roads where Tesla doesn’t recommend it.Again, missing the point. If the point is to be clear about where you should use AP, they could be even clearer by disabling it. Right?
Are you next going to suggest that we build walls along every street so that people are forced to cross at a crosswalk and not jaywalk?
Then your opinion doesn't even understand the difference between AP and FSD (among the many other things it has made clear it doesn't understand)
if(x == 1){
for(int z = 0, z < 5, z++)
y[z] = z;
if(x == 1){for(int z = 0, z < 5, z++) { y[z] = z;}}
You don’t seem to understand how compilers work, so I’m not going to waste my time. Suffice it to say, you are wrong. There is zero debate. Quote this part if you wish, but you are wrong as red as a stop sign is.The check for "is seatbelt on before allowing shift from park" would never go on the same line of code as "lock out speed while in drive above current speed limit"
Since only Teslas have AP that holds up perfectly well.
You're the one desperate to move goalposts anywhere you might sound less clueless and drag in decades old cars of other brands that don't already have "is your seatbelt on" detection built into em.
