Pinot.Noir
Can you advise which SC did this for you? Thanks.My SC was able to uncork my March 2017 100D
Santa Clara. Love that SC — everyone is super nice and even when they’re busy they take their time at check-in to make sure they understand your concerns.Can you advise which SC did this for you? Thanks.
June 2017 build 100D here. I do not have the DU00 per the config page at Tesla. Performance variable showing P1 per Teslafi. I just clocked 0-60 runs using Powertools and am getting 4.2 pretty consistently.
If I'm reading here correctly there should be more available to me with uncorking, but the P1 showing up in the API is confusing me. It seems like I should be showing P3. I am running .42 firmware.
Thoughts?
I'm still holding out hope there's going to be something for 90d owners... maybe not 420kw like the 100d but even 380kw (which previous motors are rated for) and more aggressive torque curve would be awesome.
It would also be nice if the max battery mode from P firmware was available on all cars. It's just SW
If a 90D is already able to do 0-60 in 3.8s, is there any chance of increasing its performance by a moderate degree if it is able to be uncorked? I would think it would just be minimal at best.
That's what I've always said. Crazy powerful now at higher speedsWithout a doubt the uncorked 60-90 passing power is substantially improved on the 100D.
I’m also still seeing around 4.2s 0-60. It’s a little snappier off the line but not a huge change. The biggest difference I am noticing is definitely at 60mph and above. Flooring it now almost feels like the P90D loaner I had.
We might have enough data to show this graph for the 75D but we haven't pulled the data. There was a great older graph on this with the previous generation of cars before the 75 and 100 starting here. To spoil the conclusion, 100% SoC makes a difference and is always best....what SoC is optimal for a 0-60 run, and at what point does the charge level make a meaningful difference?...
We don't have an analysis on this yet but this would mean the battery amperage limit did get uncorked. If anyone has a CAN reader on a quarter mile run they could tell us for sure. Uncorked 75Ds are now at 1300A and the 100 battery can do much more.Without a doubt the uncorked 60-90 passing power is substantially improved on the 100D...
Mine says the same. But it said that since forever i think. Whats your DU?My 90D shows «perf_config":"P1"», I am on firmware .44
Does that mean I am uncorked?
If you have a 2016 Model S 90D then no need checking. First test DU00 units installed in June 2017. The API can return option codes as can the old program VisibleTesla....How do I find out?
Neither. Old drive units get uncorked and the procedure is the same. But on the 100s it might mean very slightly different settings. And it might take longer to get it done.Does old DU means no uncorking potential? Or just a different procedure?
Krash,
I have a P100D bought as a demo/inventory with a Jan 2017 build date. From the list it seems like there was a DU01 unit (old) and a DU00 unit as of June 17’.
With the 2 tests done seems like 530kw on old unit and 580kw on new?
