OK, back to the CASE (not the CCS adapter which is in stock) which is now out of stock at Amazon...
In just one day they sold 12 of the cases, so hopefully they will restock soon. If they don't, I do see a couple of potential hard shell cases from the same manufacturer which might work.
This one is even cheaper at just $9.96 but there are currently only 14 left. It looks very similar but is not the same. The dimensions are identical to the other case, but the description states these dimensions are external and not internal (the original out of stock case stated internal dimensions). So is this in error? Even if the dimensions are external, the case might still work because there is a fair amount of flex in the case, but someone would have to be the guinea pig and try it.
First Case
This other case has the same internal dimensions as the original out of stock one. However, there is a divider in the case which does not appear to be removable. If it can't be removed, can it be cut out?
Second Case
