For the avoidance of doubt, I acknowledge that there's a fair number of CHAdeMO out there, that an adapter would be highly useful right now to a significant subset of Tesla owners, and that not having one is obviously frustrating (maybe even more frustrating than the situation of those of us in other markets who can't even order our cars yet :smile
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I hope you get your car soon!! Just think of all the speeding tickets that you're not getting while not driving a Model S.
This is false arithmetic: you can't get peak power for a DC charger by multiplying peak voltage by peak current, since you never get both at the same time (peak voltage has to be somewhat above the battery voltage at 100% charge, and you only get peak current at lower states of charge). When charging a Model S, the theoretical max power is going to be somewhere in the region of 75kW (375V * 200A).
Eh, not exactly. On current production cars, like LEAF, Tesla Model S and Rav4 EV, with about 400 volt batteries, there are limits to using 500 volts to charge. Future cars will likely be at 500 volts, and well beyond.
On the LEAF, even with the battery pack depleted to below 300 volts, the car will instruct the DC charger to supply 388 volts, ramping up to 395 volts. The maximum pack voltage is currently 96 cell pairs * 4.1 volts per cell pair = 393.6 volts.
So, to refute your premise, yes, 100kW is possible with CHAdeMO.
J1772-DC level 2 ("Frankenplug") has exactly the same power limitations (nominal 200A/500V). Looking at the two dispassionately (disregarding installed base, political factors etc), there's not a huge lot to chose between them.
Yes, that has been hashed over many times, and I agree. The two are far more similar than different, but specifically different enough to be incompatible. I wonder why?
The Frankenplug appears less clunky to handle (from its dimensions - I've not had the opportunity to handle one), but again not by a huge amount.
Everybody bases that on the TERRIBLE Yazaki "aircraft refueling nozzle" that comes with most CHAdeMO chargers. Our company, EVoasis, owns and operates the very first Fuji 25kW charger in the USA, and it does NOT use that clunky disaster Yazaki. There are second and third generation nozzles coming from Yazaki and Sumitomo. Dyden and Fuji already have UL listed nozzles that are lighter, easier to use (push the button with your thumb to disconnect, just like J1772), and more compact.
So, given the clean slate in the world that there aren't almost 3000 of one charger and ZERO of another, and no existing cars to use any (instead of almost 100,000 versus ZERO), I doubt I would personally have much opinion on the matter. One of the other, but not both.
The charging installation business is current a huge loser financially. When folks just throw around "adding" a Frankenplug to existing designs, they have no idea how much that will cost. Sure it can be done, but who will pay for it? Governments that have already spent beau coup dollars/Euros/Pounds/Yen on existing DC charging certainly aren't too keen to cough up more money for virtually zero benefit. It's only because the GM/German auto block wanted a different standard. I'm sure it's ALL above table as to why (ok, I can't hide the sarcasm... I'm quite confident why).
So, who else will pay? That's the real problem Frankenplug USA has. In Germany, they made it easy for the German spec Frankenplug. They wrote it into law/rules/regulations, but we don't have that type of central government control in the USA over commerce. GM and their appendage, SAE, have put out all kinds of press releases and whispers into government leader's ears about how they unilaterally announced themselves the leader and the standard here in the USA. Thankfully for electric cars, that isn't selling well. If GM/SAE can't starve out CHAdeMO (they have tried), out populate CHAdeMO cars (not a chance with California ARB compliance car Spark EV, IMHO), or regulate them out of business, IT'S DEAD ON ARRIVAL.
It seems likely that adapters from both to Tesla plug will ultimately exist - the specifications are there for third parties to produce them even if Tesla don't choose to do so themselves.
Tesla could choose to change the specification AT WILL for both their Superchargers and cars to reject any third party hardware/software that may come to market.
... So they should be highly motivated to do what is needed to get them [CHAdeMO adapters] access to that market. This won't apply to the chargers installed at Nissan dealers, but those are probably not the ones in the most interesting locations anyhow (and availability to non-Nissan vehicles is questionable).
I couldn't agree more, and we will wait until summer to see what Tesla has up their sleeve with a CHAdeMO adapter for Japan and USA, and presumably Europe (however, I understand there is some limitation on adapters, which is one reason Tesla uses the Menekkes Type 2 connector there).
One way this can play out is for Tesla to produce the cheap J1772-DC adapter, and the charging network operators upgrade their chargers to dual-headed CHAdeMO/J1772-DC.
Great idea... which Frankenplug station will I plug that in? The forecast for future Frankenplug installations (in comparison to both Tesla and CHAdeMO) is bleak, at best.
Another possible outcome is that they upgrade them to dual CHAdeMO-Tesla, possibly by simply installing a post-mounted CHAdeMO->Tesla adapter adjacent to the existing charging station. Since there are likely more cars than charging stations (if not, the station economics must be suspect!), this is cheaper than persuading the drivers to buy and carry the expensive adapter.
Something similar is already done at the Tesla Roadster charging stations in the USA, where at least one in Washington was a Model S adapter at the station.
There is also the question of J1772-DC level 1 - I've not seen much talk about it (and there's certainly zero stations in the wild), so it's not clear if it could be something significant or just a red herring. This allows up to 80A over the same connector as J1772, with the exception that the car end is required to have a lock to prevent removal of the connector during charging. With similar arithmetic to the above, this gives a max of 30kW when charging a Model S.
Neat idea. Something to explore, I believe.
