My experience with my 256GB PNY is it's the slowest thing on earth... it may be so-called USB 3.0 compatible, but even on my Mac, writing to it will always cause a bouncing beach ball for extended periods. GIven all that, once I get data onto the stick, it's fine for basic music playing from what I can tell... speed on playback isn't that important.
The other thing is, IMHO some USB Sticks are more problematic with Tesla than others. As I said in a previous post somewhere here (I'm always mixed up which thread we're talking about USB issues in... anywho...) I've found three different sticks from three different mfgrs that seem to cause issues with slowdown on my Tesla but show no errors on my Mac or when the same stick is used to playback tracks on a boom box I have. So, here's how I have done my own little test -- it may be inconclusive, but I don't know of another way to do this without access to diagnostics that only Tesla has to see what errors are being caused by a USB a device. Try this:
- - Remove all USB sticks from your MS
- - Find a Watch or something to time with; Start timing.
- - Reboot your CID. Foot on brake; Hold both scrollwheels until Tesla T appears; Let up on brake and scrollwheels
- - Stop timing when Media Player shows on the CID
- - Now, insert the USB stick. No need to wait for it to scan.
- - Start Timing; Reboot the CID using same method
- - Stop Timing at same place as before
- - Compare results.
MY experience has been that USB Sticks that my Tesla may not like seem to cause the boot up process to also take longer -- I suspect because of some sort of error recovery and timeout the reboot process goes through. I can't be 100% sure on this, but two of the three sticks that seem more problematic getting music to scan are also ones that are inserted with longer CID reboot times. (Honestly, I think Tesla's USB error recovery just stinks compared to other autos and devices. Tesla will tell you, like they have documented on a service invoice to me, it is their recommendation to always plug USB devices in after you get into your MS, i.e. Don't keep them pugged in all the time. Sighhh.)
In the end, try another USB Stick or another brand, and maybe that is just 2.0, not 3.0 or 3.1 compatible. All three of my problematic sticks are 3.0 or 3.1 compatible -- IDK if that's coincidence or not.
Since you compressed art down, that leaves tag data in terms of possibly impacting memory some way. IDK if it's easy for you to make batch changes or not, but I'd first try deleting all tag data that's not used by media Player (see my list above), then go after TRACKARTIST next. I have some compilation albums where there is more than 1K characters in just those combined tags on a single album (6 or more artists in the one field). I remain convinced in my case that reducing that data allowed all my tracks to scan once again, just as it did in 7.1.
Remember, Tesla seems to have rewritten a major part of Media Player and tags are being used quite differently in 8.0 than they were in 7.1, so only Tesla Engineers could really investigate where their logic has introduced new problems and consumes more memory. Assuming that's the problem, Tesla still does not seem to have elected to put a hard limit on the number of things supported, throw-up an error and stop as it reaches a threshold -- instead things just seem to still slow to a crawl until maybe eventually something happens or the CID reboots and it tries again. Phewww.
Good luck.
