Coronavirus
winfield100
2,741
9,827
vivant non-traveler
I have a feeling it's borders at other countries where they may have some future value. Not locally.
yes locally
have you been to Krispy Kreme donut shoppes yet for your _free_ glazed donut,
show your vaccination card
(your cardiologist will know for sure)
madodel
X at the end of a rainbow
Apr 6, 2015
2,430
9,741
Poconos, NE Pennsylvania, United States
As I see it the card is also a receipt that denotes when, where and from who one got the vaccine so if later when/if there is a federal registry to help with travel/work requirements you have some documentation of it happening in case the Feds have no record of it happening. My wife got hers at her hospital so it should be in her chart there but she also still has the CDC card. I assume pharmacies record it in their systems as well so maybe it won't matter if you have the card.
AlanSubie4Life
Efficiency Obsessed Member
Oct 22, 2018
9,238
11,035
San Diego
Even more galling are the Florida statistics that ignore every spreader who contracts the virus but then return to their home state to spread it and get counted there. So the actual rate of infections in the Sunshine State is obfuscated.
I agree the numbers are probably obfuscated, but I think the emphasis and focus on Florida as the source of all things evil Spring Break related is a bit overblown. And if this were happening to a large degree, it would show up in case numbers in Florida too - it's not like the virus selectively targets tourists & Spring Breakers. It's really the millions of other people conducting Spring Break activities nationwide (even traveling to Mexico and other countries) which matter. Florida is a small but significant piece of this, but it's not the only piece. The local rises in Michigan and other states are unlikely to be related to Florida, for example.
And if you look at Florida, infection rates are starting to rise, mildly. I hope they can keep things under control as the weather heats up.
It really does look like we're starting to get a confirmed rise in cases now. Guess we'll see how it goes. It really is interesting (and completely mysterious) how places like California and (to a lesser extent) Texas are doing great, while New York, New Jersey, Pennsylvania and Michigan are doing terribly. Florida isn't doing great either, but they're kind of middle of the pack. It is just so hard to understand the reason for local patterns. It seems pretty clear that you cannot look at state-level mandates and expect to learn anything.
I guess they should start harvesting plasma from people who have had both doses of the Pfizer vaccine, since that serum is likely to be more effective than the inconclusive results from convalescent plasma (it has much higher antibody levels). They can also get plasma from people who were previously infected who are coming in for their second (probably unnecessary) vaccine - can combine the visit! Seems like we're going to need this plasma for the young people! Seems like it has to be used early though.
rxlawdude
2,248
1,542
Orange County, CA
Convalescent plasma has a rather iffy record. For the latest on the US FDA EUA, see FDA Updates EUA for COVID-19 Convalescent Plasma
Reactions: JRP3
AlanSubie4Life
Oct 22, 2018
9,238
11,035
San Diego
Yes, the results of convalescent plasma were not great (I suspect partially because not used early enough and I could see that being a difficult decision as it's probably not without risks - looks like that's how the FDA tweaked their guidance, too). That's why getting vaccinated plasma might well do better, theoretically. Since it's 10-100x more potent than convalescent plasma (and all the antibodies are likely effective). But I have no idea. It does appear that people are starting to look at this. It's thought that plasma from a convalescent who has been vaccinated might actually be the best, perhaps?
So maybe vaccinated plasma used early (should be ample supply now!) would have notably improved results?
Lancet Journal Link (a letter): Convalescent plasma from people vaccinated after COVID-19 infection
rxlawdude
2,248
1,542
Orange County, CA
Interesting concept proposed, but of course at this time there are no data to back up its use. In theory, convalescent plasma should work, but results (as mentioned) overall are not that impressive. In theory, fluvoxamine may work to reduce intensity of COVID-19, but with less than a couple of hundred subjects, too early to get excited. I guess the side effects of that result in less OCD behavior and depression. o_O
Reactions: AlanSubie4Life
AlanSubie4Life
Oct 22, 2018
9,238
11,035
San Diego
For sure, but as they say, there are a few factors that make that result make sense:
1) Getting good antibody titers in plasma has been tough since natural infection leads to a sub-optimal response. And the timing has to be right.
2) Early use is key. (FDA has adjusted their guidance.) After damage to the body and the systems has occurred, which takes some time, it's probably of limited utility. (The virus multiplies quickly in the nose which is why presymptomatic/asymptomatic spread is such an issue, but it takes a good long time to damage the rest of the body.)
3) Fully vaccinated sera is way, way more neutralizing than natural infection. The really high titers probably make timing of collection less of an issue.
I guess we'll see. I assume someone will try this soon - I don't know whether it requires FDA approval to explore, especially if you take it from previously infected vaccinated folks.
rxlawdude
2,248
1,542
Orange County, CA
I can just see those plasma centers downtown getting a bunch of (vaccinated) donors wanting cash to buy that next bottle or ounce. :)
EVNow
9,303
27,869
Seattle, WA
It’s because of the bird brained governors relaxing rules as soon as the last wave recedes.
It’s like celebrating every weight loss milestone by pigging out for weeks.
AlanSubie4Life
Oct 22, 2018
9,238
11,035
San Diego
But, it’s not quite so simple...why is Texas doing so relatively well? Whitmer isn’t exactly an anti-masker either. Why is everything blowing up there? Weather? Variants? Luck? Local Restrictions? Why is B.1.1.7 growing faster in some states than others? Differing vaccination strategy or acceptance in critics populations?
I honestly have no idea. My understanding is that mask compliance in Texas hasn’t actually changed much after lifting of the statewide order but I can’t actually find any data.
My general feeling is that there are so many inputs to the situation in each state that differ so much that it is difficult to disentangle them all. And I have no explanation for the results. No idea.
I do agree that maintaining restrictions through March would have been helpful, probably. I think we’d see much lower case numbers now if we had, and I do think NPIs work in general. But sometimes it feels like pushing on the end of a string since they are not always sufficient.
nwdiver
7,566
9,661
United States
Anecdotal but when I was in Andrews a few days after the gov lifted the mandate there wasn't a mask in site in any of the indoor places I stopped by.
JRP3
Hyperactive Member
Aug 20, 2007
19,561
43,023
Central New York
Starting Friday, New Yorkers will be able to pull up a code on their cell phone or a printout to prove they've been vaccinated against COVID-19 or recently tested negative for the virus that causes it.
The first-in-the-nation certification, called the Excelsior Pass, will be useful first at large-scale venues like Madison Square Garden, but next week will be accepted at dozens of event, arts and entertainment venues statewide. It already enables people to increase the size of a wedding party, or other catered event.
jerry33
Mar 8, 2012
19,565
21,936
Texas
From what I can tell, mask compliance is about the same. The weather pretty much shut everything down for a week, so no one left their homes unless they really, really had to. Even though I'm not in one of the areas that lost power, ice days are not the days you want to go driving or walking. One week of no one going anywhere probably did put a big dent in the spread. And it's been warm since, which is not particularly friendly to the virus (my understanding).
dkemme
332
852
Greeley, CO
My wife had to do a TEE (TransEsophageal Echocardiogram) on an intubated COVID patient yesterday. Even though she is fully vaccinated she still triple masks. Again she says the patients in the ICU now are very sick and most will probably die. She doesn't have the statistics on them since she only reads the charts on those she has to do consults or procedures on. But it's getting grim again. Though still not many COVID cases in the hospital, just sicker people.
Same here, no decrease in hospitalizations, just steady increase of higher intensity illness.
got it, smallest needle I've encountered since I was kid.
Seems like TN is opened up quite broadly, I filled out a super long form, made an appointment, brought an essential worker document with me and some one with 0 special classifications of any kind got the vaccine while I was there, no prior appointment.
Vaccinations clinics are not enforcers, they rely on personal responsibility to define if they are eligible. Our system struggled with how to define who is eligible. We found no reliable method and chose personal responsibility.
I've been Pfizerized. Second shot is done with no side effects at all. I wish they'd made this vac card wallet size.
After the J&J, my friend posted she was Johnson'd last weekend.
Maybe horse serum?
dhanson865
4,385
5,919
Knoxville, Tennessee
It wasn't that they didn't enforce it, it was that they specifically told her she didn't need to wait. See below for a timeline and further clarification.
When I made the appointment my county was on phase 2 of vaccinations which is filled with various classes of essential workers.
Things looked like this
I specifically went in as part of Phase 2 because I was too young to get in by age.
but when I got there the woman behind the table told my friend there she didn't need to wait for April 5th because it had opened up already
It still says this for the county in question
my friend told her she was waiting for april 5th and was just there waiting for me to finish but the woman taking the forms handed her a blank form and said it didn't matter what classification she was in, that they were giving shots to anybody. No reason to wait until April 5th like the website said.
So the person in question was under 45 but was given the vaccine right then and there because there is no shortage of supply apparently. This was around noon with a steady stream of people coming through before and after us. They weren't just giving it to her because it would go bad otherwise.
scottf200
3,831
3,406
Chicagoland ModelX S603
1) Good past few days.
My remaining unvaccinated sibling did the J&J on Fri.
Our kid 2 received their 1st Pfizer Fri. (Kid 1 had their 1st already).
My wife and I were able to book both doses Sat at a near Walgreens for this coming week. 2nd does is scheduled 28 days later so we are assuming we are getting Moderna.
2) By chance, I was just listening to a short clip from Maddows show about monoclonal treatment and that it is available and 'free' for at risk patients. Just something to keep in the back of your mind for any friends/family/etc.
KG M3
160
245
Pasadena, CA
Got our second dose yesterday at Walgreens. Their system automatically sets the second dose 28 days later. If you get J&J, they cancel the appointment. If you get Pfizer (we did) you can reschedule the second dose (starting on day 20) for 21 or more days after the first. We spent way too much time on their system figuring this out. . .
Yuri_G
753
2,574
Raleigh, NC
You can also schedule a second shot only with CVS if for some reason you can't get the second shot at the same provider that gave you the first. I was impressed with their setup. Fill all of your info out online, then in and out of the store in 20-30 minutes.
