trmmcd
As a stop gap (pun intended), can you place/hang a more obvious artifact in a place the FWD does see and avoid it? Then enable the save this location routine. Then remove the artifacts and maybe MX will remember some possible damage it could not see before.
If it works, you can play with artifact placement to optimize how FWD open in your garage.
Funny you should suggest this. I did originally hang a $2 kite over the sensor but I had trouble stabilizing its profile and had to hang it a couple of inches lower than the garage door. It did work - sort of - but I took it down out of optimism over a pre-release of the lift gate fix - which I love. Still no love for the FWD. I also found explaining the kite to be a bit embarrassing
