My original battery was a trooper. It would range charge to 257 just before it died suddenly from the clunk at 4500 miles. Degradation of range had only started on my original A pack when I started 50-70% instead of 90-93% charging the car. I also used to charge at less than or equal to 24 A @ 220V. When Tesla added the slider and said 40 A would save power, I stopped doing this and that is when the pack went from 260+ downward. I would not advise charging 50-70% ever and would charge at lower amperage if that is practical.
More data and food for thought:
My 2012 Signature P85 with its refurb A pack just hit 9100 miles. I had a 90% charge of 227 on 5.9 and have a 90% charge of 226 on 6.0.
My refurbished A pack battery started with less range miles (250) and seems to be losing miles much more quickly. Pointing this out to Tesla indirectly and also directly has led nowhere really despite efforts to increase it back (firmware 5.8/9 was the only thing that truly helped). I suspect at the end of the day my refurb A pack had more miles on it than my original A pack (~4500).
You had a different pack, different charging rate and different target SOC. I don't see how you can draw any conclusions from that at all.
@Walla - What charging parameters did you use when you received your refurbished pack?
All I know is degradation was minimal when I used to charge at 90-93 at lower amps.
I have gone back to that now to halt my loss of range and so far that has worked. So I do feel I can write what I wrote.
For what it's worth, unless I'm charging on 120V, it's always 40A. My range has not dropped much, so I don't think that lower power charging is related to anything.All I know is degradation was minimal when I used to charge at 90-93 at lower amps.
19,000 miles on original A pack with 228 miles at 90%
All I can say is that reading this thread is making me nervous as hell about how I treat the car. There's absolutely zero credible information about what is the best way to treat the car. Just a whole lot of anecdotal cases. For all I know I should do a little dance when I plug in the car to avoid problems.
(but the ocd folks will claim they just need to do some balancing) .... Basically, just relax and enjoy.
This thread is an amazing collection of owners, all having the same problem, decreased rated range beyond the expected degradation curve and in most cases it seems to be related to daily undercharging. Maybe its time to draft another open letter to Tesla to review this issue. I have SC appointment this week and plan to ask, however, I am not encouraged that I will have any confidence in the response I recieve as there is obviously no corperate level guidance on this issue.
You're a new owner? I'm confident you have nothing to worry about. Your D pack will hold up quite well given that you charge it to 80-90% daily and 100% only when you need it.
You ...don't... do the dance? Oh, man, I'm so sorry. I'll come with you when you get your battery replacement if you need a sympathetic ear.All I can say is that reading this thread is making me nervous as hell about how I treat the car. There's absolutely zero credible information about what is the best way to treat the car. Just a whole lot of anecdotal cases. For all I know I should do a little dance when I plug in the car to avoid problems.
And most are somewhere in between these two extremes.The summary is that some people are meticulous about how they treat the battery and others don't care at all.
I don't always make the best choices regarding personal health but this is one of those examples where I choose to "let it go" and if my battery suffers some amount from not being "meticulous" then so be it.Or, you could just follow Tesla's official recommendation which is to charge to 90% and plug in whenever possible.
I am now charging the car to 90% and not thinking too much about it.
