Easiest way to tell a Y from a 3 if they are not next to each other?
For whatever reason, I find it easiest to look at the rear.
* In a Model 3, the license plate is right up against the trunk opening. The rear glass also "stops" well above the trunk
* In a Model Y, the license plate has a bunch of room underneath it. The rear glass stretches much further back, since it's a hatch not a trunk
Thanks for attaching the annotated pix!
Most Model 3 vehicles have chrome door handles. If the vehicle is parked I check the wheels. Model 3 wheels and aero covers don't look like either the Model Y 20" Induction wheels or the 19" wheels with the Gemini covers.
I've only seen one or two Performance Model Y (PMY) vehicles. The easiest way to spot a PMY is the spoiler. If you can get close enough to see there is a red stripe beneath the Dual Motor badge. At a distance the PMY 21" Uberturbine wheels don't look all that different from the 20" Induction wheels offered as an option on the Long Range Dual Motor Model Y (Standard Range Model Y too.)
Reactions: Alexgd
This is a wonderful annotation but you're missing the most prominent differences; and that is the black hitch trim at the bottom. That's the easiest way to tell both from the rear.
To tell the apart from the sides, Model Y has black trim around the fenders and black trim side skirt.
The front is a bit trickier but the Model Y doesn't have a lower lip that looks like a "front lip spoiler".
Pic below for both of those mentioned above:
From easiest to more difficult:
If it has silver trim, its a 3.
If it has black wheel arches (rocker panels) its a Y
if it has long side mirrors, its a 3,
short, tall side mirrors, its a Y
if it has aero, or sport wheels its a 3.
Gemini (Tesla calls them Apollo) or Induction wheels, its a Y. Hard to tell when in motion though.
If the trunk opening line is low, its a 3
Y has a higher sitting trunk opening line.
Reactions: Alexgd and Darmie
From behind, the Y has space between the license plate and the bottom of the trunk, the 3 does not:
The S and X can be distinguished from each other the same way.
The S and X can be distinguished from the 3/Y in many ways, but the most obvious to me is the recessed part of the rear trunk/hatch (where the license plate is installed):
Reactions: ArtK
