Firmware 5.9
PhilBa
1,382
68
Seattle
And I've had them show up after having been in the parking lot at work during the day.
I'm pretty sure they stage the cars in reverse numeric order of the 7th digit of the VIN, but only on odd days of the week unless the month has an even number of days in it.
You forgot the phase of the moon and whether they had beans for last night's dinner.
AmpedRealtor
6,342
3,312
Phoenix, AZ
It's standard practice to roll OTA updates out in batches. For several reasons: problems are isolated to small groups and found before affecting the entire customer base,
loads for server infrastructure can be balanced, etc. The first reason has already been important in a few prior updates.
Except that was not at all the case with 5.8, which removed suspension lowering. Everyone had that update in a couple of days.
I'm still on 5.8.8. I'm also on wifi. My VIN is 16XXX. Always the last to get an update, it seems.
mnx
2013 P85
May 6, 2009
2,286
7
Ancaster, Canada
Yeah, next time I feel like I'm the first to get an update, I'm going to pass! :)
tomas
Out of warranty...
Oct 22, 2012
4,229
3,798
Chicago/Montecito
Agree that 5.8 was rolled out more quickly than most, but "everyone" did not get that in a couple of days. I did not get it until 2+ weeks after the blog. Good 3G reception, nightly WIFI.
5.9 is out for, what, 3 days? To all: plz be patient, you are nowhere near last to get it yet! You can start that talk around tax time. If you are in a rush, stop by a service center, they'll oblige.
Lawsteve
MCATDT
Aug 12, 2013
737
464
Tampa, FL
Does 5.9 make any improvement to the upgraded audio package (e.g. Dolby actually works, better communication with iOS devices)?
re timing of OTA distribution, there appears to be no pattern. I believe I was an early recipient of 5.8.8, but have not received anything since then.
i do not believe they distribute only on days ending in Y, I think it is only on days that contain a "d." I also believe those of us who are left-handed are given priority.
wk057
Senior Tinkerer
Feb 23, 2014
5,651
11,371
Hickory, NC, USA
So I have the car on Wifi, and since my router is a Debian based PC basically, I setup a script to alert me if its data usage jumps... presumably alerting me to when its downloading the update.
Is this overkill? :tongue:
Lycanthrope
S3XY old dude
Nov 15, 2013
8,665
65,944
At home
I realise software updates are sometimes rolled-out gradually, but I don't believe it's the case here. After all, we're talking about a walled-garden with the Model S, so other than the small variation in the different models it's a very predictable scenario.
Also, I do believe that these updates undergo rigorous testing both in-house and by selected beta testers - we're talking about the software controlling a two-tonne missile here, you have to be more than certain there are no glitches as any bugs can result in death or serious injury.
So I don't subscribe to this idea.
But I could be wrong...
glhs272
Unnamed plug faced villian
Aug 21, 2013
909
563
Burlington, WI
Doesn't the car max out at 130mph anyway? What's the point of 140+? :confused: In case you go downhill with tailwind on a racetrack?
When I topped out my 60 at 122mph it seemed like it had a lot more to go. It seemed to cut the power off. Maybe they raised he software speed limit.
jamieb
157
6
Sacramento
Originally Posted by jamieb
....during a utility emergency when they hike peak rates for EV users to 1-2 $/kwh in the summer.....
how do they know you are using power for ev? That seems illegal.
To qualify for the lowest rate for my utility, I installed a separate time-of-use meter for EV charging with two NEMA 14-50 plugs on either side of the garage being the only circuits on the meter. Qualifies for very low rates at off-peak times, but much higher rates during peak use and punitive rates during periods of anticipated brown-outs (e.g., serious heat wave). Common with many utilities. See: smud.org
NJ Plugin
529
105
From what I heard, you have to bring the car for some kind of service. When they fix that, they also update the firmware. You cannot just go over, and ask for an update.
By the way, even though I said I got the update notification in the afternoon, when the car was not on WiFi, the car does connect to my home WiFi whenever it is parked at home. So it's not like I never use WiFi.
Two weeks ago I was at the Service Center, and they said I had a few minor service bulletins to check (check the Pano, and one on some side trim), and I should set a appointment to have done. Yesterday I called to set the appointment, and he told me the service bulletins, and one was to upgrade to 5.9.
So if you are itching for the update, you might try calling and asking if there are any service bulletins for your car.
tomas
Out of warranty...
Oct 22, 2012
4,229
3,798
Chicago/Montecito
You are obviously new to the Tesla rollout process, which IS gradual, there's not even room for conjecture and discussion on the point, there is evidence from 15+ updates since launch.
Stoneymonster
1,787
1,064
Aptos, Ca
Their track record of pulling updates and releasing bugs would suggest otherwise. Also, I don't know how much experience you have with software, but on a device this complex, there's always a scenario you didn't anticipate.
gnychis
303
0
Boston, MA
I've found the "hill hold" function to be slightly underwhelming. It must be looking for steeper hills than I'm thinking of. But if I'm at a traffic light up hill, it seems to sometimes do the hold for me, and sometimes not. On the same hill I get this "occasionally" behavior. It's not THAT steep, but I definitely quickly roll back. So I've found the functionality to be a bit periodic rather than very proactive about preventing roll back.
AlMc
'When the music is on...you gotta dance' (Go Elon)
Apr 23, 2013
7,346
15,494
Delaware
I have heard that the beta testers typically get the first version of a new release 2 months before general release and see many 'bug fix/suggestions from them for changes' versions.
ACDriveMotor
890
24
Seattle, WA
I like it. I find myself checking the car at night to see if an update came in. I think I wish that the REST interfaces could let you query for a pending update. I might even choose to initiate an update remotely if I could do so.
hj-45
161
0
Dover, NH
Received 5.9 OTA 2 days ago. With the 40kw, I really appreciate my winter charge going from 126 to 136 miles. The change to bluetooth is also welcomed.
Kipernicus
Model S Res#P1440
Dec 2, 2009
1,255
135
Belmont, CA
Service Center gave me 5.9 while the car was in for backup camera replacement, leather repair, and 12v replacement (pre-emptive on their part, I didn't request).
Just finished a 90% charge and I'm up to 175 miles (was 167 before). Have yet to see what it's at for 100%.
I like the hill hold and air suspension adjustment, but don't like how artist/album were switched around in Slacker (why even go through the trouble?), and would like to regain ability to turn off the supercharger and prior charging location pins. Didn't notice any changes to speedo (I just look at the big number) but will look for it tonight.
Dave EV
1,651
970
San Diego
There is a rumor (totally unsubstantiated, IMO) that 60 kWh cars may be able to SuperCharge faster than 105 kW on 5.9.
Can anyone confirm or deny?
I guess 90 kW limited 85 kWh cars may want to re-test after getting 5.9, too.
