Ok, wow. But, thoughts…
(These touch on some topics already raised in previous comments, but I think they deserve more focus.)
- Charge port locations: Ford’s charge ports are located on the left side just in front of the driver’s door. I read on a Ford Mach-E forum that the charge port is 47” from the front of the car. With V3 Supercharger cables being ~6 feet long, I’m thinking they’d be long enough to reach if the Mach-E pulled in nose first. But then they’d effectively be blocking 2 stalls since they’d be using the plug on the left side of the parking space whereas Teslas reverse in and use the plug on the right side of the parking space*. That is, unless the “Tesla designed adapter” has a pretty long cable attached to it, but that seems unlikely to me for some reason. (And enforcing Ford owners to reverse in seems like it would be a losing battle.)
- 2025 Ford EVs to get only NACS ports??? The announcement says that starting in 2025, Ford’s EVs will get a built-in NACS port, eliminating the need for a Tesla adapter. What it doesn’t explicitly say is that they will eliminate the CCS port rather than have dual ports. Given that the number of CCS charger locations in the US is poised to expand significantly with all the IRA money now available, it seems a bit odd for Ford to ditch CCS altogether at this time. A CCS-to-NACS adapter could obviously address this, but it still makes me wonder.
*I’m ignoring here the few Supercharger stalls that have the pedestal located on the side of the parking space. Those might reach the Ford’s charge port, although it might require not pulling all the way into the parking space when the pedestal is on the left side. When it’s on the right side, I’m not as confident if it would reach since the Ford would only be able to back in so far before hitting the curb.
