Has anyone upgraded the USB ports to support faster charging?
Discussion in 'Model S: Interior & Exterior' started by BrettS, May 2, 2017.
  1. JasJ
    JasJ Member
    Houston, TX
    Hope you took photos. I'm going to replicate what you did if I can figure out the route you took. Thanks for the long description.
    Ordering the MotoPower now.
  2. CSFTN
    CSFTN Member
    Memphis, TN
    You have a newer car, with the integrated console? If so, did you measure amperage at the USB ports providing power to the rear seats?
  3. BrettS
    BrettS Member
    Orlando, FL
    #23 BrettS, May 4, 2017
    Here are some pictures. This first one is taken inside the console toward the front. You can see the holes in the 'roof' of the console. Most of the holes are covered by the sliding cover when it's open, but the ones in the very front are not.
    This is taken from inside the console pointing toward the back and up a little. You can see the cover that goes over the phone dock, which is closed now, at the top of the picture and the phone dock in the middle. I reached under the phone dock plate to mount the new USB connector. The wire for it is running down and to the left.
    Another shot of the phone dock connector and the wire running along the inside of the console. The rubber floor of the console has been removed.
    This shot is from inside the console pointing to the front. The rubber floor of the console is back in place and covering the wire run except where it goes up and out through the hole. This is the only spot where the wire would be visible, but really it's all but impossible to see the very front of the console without sticking your head (or the camera) into the hole.
    This next shot shows the area between the screen (you can barely see the screen) and the top of the console. I removed the cubby under the screen to take this picture. The cubby has four latches... two in the front two corners and two in the back two corners... push it straight down to release the latches. Push down the front first, then reach your hand inside to push the back down, once all four latches have been released you can slide it forward and out. Once it was out there was a tiny little sliver of space under the wires you can see in the picture and next to the foam above the console where I could see the wires poking through as I pushed them up into the hole on the roof of the console. Once I found the wires I was able to stick a screw driver through there to push the wires to the right and forward so I could get to them from the passenger footwell. Getting the wires through here to where I could access them in the passenger footwell was the hardest part of this whole thing.
    My new wires coming down and connected with tap connectors to the black (ground) and red w/white strip (switched 12V accessory) wires. The purple wire on that connector is for the cigarette lighter, so you could use that as well.
    Here are the wires taped off and pushed back into place and ready for the trim to go back on.
  4. BrettS
    BrettS Member
    Orlando, FL
    My car doesn't have USB ports for the rear seats, unfortunately.
    On a side note as I was doing this work I noticed that the USB plugs in the console have little lights in them... presumably to make them easy to find at night. But what I discovered is that the lights are powered by the USB port... when I disconnect the mini USB plug the lights go off. I'm wondering just how much power the lights draw and if this is why I'm seeing less available power on those plugs vs a standard (unlit) cable.
  5. JasJ
    JasJ Member
    Houston, TX
    @BrettS Thanks for the pictures. Just what I needed.
  6. BrettS
    BrettS Member
    Orlando, FL
    Good luck. Let us know how it goes.
  7. BigD0g
    BigD0g Active Member
    Somewhere
    Any pictures of the process ? =).
  8. BrettS
    BrettS Member
    Orlando, FL
    Yes, see above:)
  9. nnick01
    nnick01 Member
    Bay Area, CA
    Just an FYI. My 2017 MX100D (stock) has two 1000mA USB ports in the front, and three 1500mA USB ports in the back. I also have a flush mount cigarette adapter that has two ports at 2500mA in the front. I find it odd that the front ones are less mA than the rear.
    I tested this all using an app called "Battery Life" on my iPhone.
  10. BrettS
    BrettS Member
    Orlando, FL
    #30 BrettS, May 5, 2017
    Out of curiosity, are the rear ports lit? As I said above, the front ports have a little lights on them that are powered by the USB ports, so I suspected that the lights might be taking some power that would be otherwise available to the phone. If the rear ports aren't lit, then that may explain the difference.
    The other thought I had would be if the rear ports are connected to the radio at all... can you play media from devices plugged into the rear ports? If not, then it may be that the front ports are connected to the radio and getting their power from the radio, which only supplies one amp while the rear ports are connected to some other power supply and whatever they are connected to can provide 1.5 amps
  11. BigD0g
    Somewhere
    Apologize for that! I was on a crappy internet connection earlier so I bet the photos just didnt load fast enough for me.
  12. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County Virginia
  13. planx
    planx Member
    San Francisco, CA
    Could somebody do a video guide of the process? I’m not a pro, and the pictures were not enough for me to replicate the modification
    Thanks for anyone taking the time!
