Gauss Guzzler
Safety Score = 42
Well, there’s also the possibility that he’s still walking home from the airport.
I've never had the percentage go up, only down. I don't know what you mean by true drain though. Anything that's using car battery is drain right? I've gotten some feedback from Tesla support that the battery is kept warm in cold temperatures and cool in hot temperatures. Also one time the fans ran while parked to dry out the air filters. The battery still takes a whack often. 2% in two quick 45 minute stops over the weekend.My battery drops 2% overnight sometimes, rises 1% overnight (not plugged in) other times. How do you know yours is true drain?
The % reading is the Battery Management System’s (BMS) best estimate of how much juice is in the battery. It’s an estimate because it can’t count the actual electrons.I've never had the percentage go up, only down. I don't know what you mean by true drain though. Anything that's using car battery is drain right? I've gotten some feedback from Tesla support that the battery is kept warm in cold temperatures and cool in hot temperatures. Also one time the fans ran while parked to dry out the air filters. The battery still takes a whack often. 2% in two quick 45 minute stops over the weekend.
I'm a new owner but fwiw given your description that seems about what I'm experiencing. I found the energy app on the car to be very insightful. Have you looked at it?Power off?
I've had really bad drain this week. Charged to 205 miles on Tuesday (6 year old S75D - 60k miles). Drove home (20 miles) and have done three short 2-3 mile trips since. I know it is cold (Cheltenham) and short trips are not ideal particularly in the cold but I'm down to 130 miles including losing 12 miles (6% since 1:30am today) without going anywhere.
I may be on the original 12V battery (I had it serviced just before the four years were up and, tbh, I don't know if the 12V battery was replaced so I assume not).
From this thread, I gather that it may be multiple recharges of the 12V battery causing the loss. Is it wise to power off the car or would that just about 'guarantee' that the 12V battery would go flat.
TIA for any tips
I have seen similar behavior a few months back with the original battery but after I "preemptively" replaced the battery, I haven't seen anything like this.Power off?
TIA for any tips
Power off from the menu really doesn't power off based on my observation. The screen sure comes up quickly when opening the door to be in a full power down mode.From this thread, I gather that it may be multiple recharges of the 12V battery causing the loss. Is it wise to power off the car or would that just about 'guarantee' that the 12V battery would go flat.
Yep, I have no clue what it does.Power off from the menu really doesn't power off based on my observation. The screen sure comes up quickly when opening the door to be in a full power down mode.
Blanks the screen for napping? That's all I can come up with.Yep, I have no clue what it does.
