matt_in_ca
I'm curious as to whether anyone without the UHFS has installed and can recommend aftermarket speakers for the rear liftgate?
Very interesting. Is the bass actually good with the ETON setup, or just a lot better, but not all that great? It seems like the stock head unit would not put out enough power (rated at 200w) to push good bass with 8" speakers.
So you need to fabricate custom spacer to install an 8" speaker in a model S? That's the only way it'll fit, even though the UHFSS has an 8" speaker? I'm guessing you would need to ruin an UHFSS speaker to get the parts you need.
I do like the simplicity of not having to run wire to amps or subs.
I think the answer to your question is relative. If you're into hip hop, then the ETON setup probably won't be sufficient, as it won't "hit" or thump enough. But if you're into rock, classical, EDM, etc., the ETONs sound AWESOME.
It's not just better than the originals, it's actually very, very good. Deep, rich bass. I think it's a good starting point, for if it's not sufficient, you can add the Light Harmonic amp and subwoofer.
And I think a bit of fabrication comes with the territory of anything that isn't factory designed or drop in. It wasn't a big deal for my shop (or big expense for me) to put together the spacing.
Matt
So from what I understand, the Eton's are 3 ohms and the stocks are 2 ohms. I'm guessing the additional ohm doesn't really have an affect on anything?
Also, you pretty much bought the Etons only for the 8" speaker and did not use the tweeters for anything correct?
I have a 2017 MS with the PUP that includes the UHFS and am considering changing out at least the door speakers. Do you think this would make any difference in the sound if I already have the UHFS? Thanks.
Technically speaking, I don't know. Acoustically, it sounds fine to me, all the way up to volume 11.
That's incorrect. I put the speakers in the A-pillars, replacing those that came with the car.
I don't know. I've never heard the UHFS.
Yes yes and no.
I installed those.
I have no more need for a sub woofer
Second row:
There is absolutely no need to install those in the second row since there is no bass. Never will. There they cut digitally all bass off to not have overlapping sinus waves. What you can do since you throw away from the Eton set the tweeters anyway-
I think I'm going to go with the ETONs.
Matt, in your pics, the tweeter is in the door. Did you take it out and move it up to the A-pillar? Or am I missing something (there a secondary component tweeter?)
Treyloader, have you heard the UHFS? Any opinions on how your setup compares to it?
Trayloader, have you heard the UHFS? Any opinions on how your setup compares to it?
You have many choices... At first I went with NVX, but I am an audiophile so I changed to an Illusion Carbon C10. I had custom work done. Attached are some pics.
The first is the NVX. The last two are the Illusion. The custom work is the lighted "T" and the installer autographed it! It ties in with my lighted puddles lights, lighted rear T and (of course) lighted rear appliqué.
Good luck!
I'm shocked you noticed a difference at all if you didn't add an aftermarket amplifier. I pretty much gutted all the factory speakers and went aftermarket, but I added a 5 channel Alpine amp to power everything. I have to admit that turning my volume to 4 out of 11 can be overkill though.Ok, just did my system upgrade today, and boy am I thrilled!
This is what I did:
Thanks to trayloader, I went with Eton 200.2 for the front doors and a-pillers:
ETON POW 200.2 20 cm 2-Wege Kompo System Compo Speaker Car Speaker | eBay
For the rear doors, I went with Focal 165x2:
Focal PS 165X2 6.5" 80 Watts RMS 2-Way Component Speakers System
WHAT A DIFFERENCE!! Like trayloader, I didn't go with a subwoofer or amp. Just the aforementioned. And the sound is absolutely beautiful. The 8" Etons are rich with bass. I played with the equalizer and balance for quite a while after the install and settled on the attached parameters, which allows the Focals to complement the Etons perfectly.
View attachment 270091 View attachment 270092 View attachment 270093 View attachment 270094
An amp and subwoofer are options for the future, but for right now, the sound is loud enough and super rich. So I'm a happy camper.
Some install photos are also attached, showing the custom ring the installer fabricated to allow the speakers to sit properly.
Many thanks to trayloader for his guidance on this project!
Old school Bowers and Wilkins Floor standers 600 series...
