Safe to update!Let us know how the install went. Woke up to this firmware update. Hope to give it a try after work. This will be my first FSD Beta for the Y.
You can try to remove the glove box.Hi guys , just about to destroy my hands, any additional install tips havevrhevtime helpful bstuff here. , any body go a diagram of the extension cable that has been suggested.
Plan to use it for auto cross, is there a way to keep , Abs and Regen but loose the nanny stuff?
Thanjs
I had a LOT of trouble putting mine in.Do you have large hands? I have had to take mine in and out at least a dozen times, it's a bit annoying, but really dont have much trouble at all doing it. For reference I wear medium sized gloves, so I do think my hands are on the smaller side for an adult male.
Yes, good so faranyone on 36.2 yet? safe?
Worked for me.anyone on 36.2 yet? safe?
It wasn't that easy for me even bending the wire 90degs. Ingenext came out with instructions on removing the glove box. I think if I need to do it again, I'll go this route. Quick write up on it if that will help.Oh boy, well this will make you laugh but I am 78. Have stripped out front suspension a few times, even adjusting could overs is a bit tricky. Due to replace front drive shafts hopefully the week after next. So it's upside down under the glove box, ha thanks will keep you posted at least it will provide a laugh.
Removing glove box.docx
Take the bottom piece off where the speaker is located. Pry the side plastic panel off . Lift up on the wooden piece.docs.google.com
The Ghost upgrade does have lap mode kind of like track mode. I haven't had much luck with moving the sliders around making any difference.
I bought the long pliers with a 90 degree bend off Amazon. Took me about 60 mins by hand first time. Second time with the pliers I was done in minutes. Trust me, it is easy with them! I keep them in the car should I ever need to remove it quickly.Thanks think I will go the glove box removal route.
Linky please.I bought the long pliers with a 90 degree bend off Amazon. Took me about 60 mins by hand first time. Second time with the pliers I was done in minutes. Trust me, it is easy with them! I keep them in the car should I ever need to remove it quickly.
New Quality 11" Extra Long 90... https://www.amazon.co.uk/dp/B08NX2ZDJR?ref=ppx_pop_mob_ap_shareLinky please.
i saw this too, are they talking about regen in the ingenext app?Latest update says:
Anyone know what is the issue?
- 2022.36.2 Safe with the Nice try module installed (DON'T use the regen feature in the Ingenext web app if you didn't do the update we sent you)
Yes, there is a regen toggle in the later firmware versions of the Boost modules to bring back Regen options since Tesla removed it from recent Model 3 builds. That option is still available for older builds stock, so a lot of people don't actually need to use the feature. If your module doesn't have the option, it probably hasn't been updated since they added that feature.i saw this too, are they talking about regen in the ingenext app?
