This document makes absolutely no sense! Say a vehicle is moving at 5mph, there is absolutely no affect on range between 18" and 19" rims. The faster the vehicle goes, the more affect on range between wheel sizes, not vice versa. Where are these data points coming from? Show us your algorithms and formulae.
It makes sense to me, rolling resistance is the dominant driver of the difference until the aerodynamics start to take over and they start to converge ...
From the 2nd to the last page of the document :
Vehicle Configuration # 0
Gross Vehicle Weight (lbs) 4805
33% Curb Mass (lbs) 3837
Loaded Vehicle Weight (lbs) 4137
Equivalent Test Weight (lbs) 4250 (4126 ‐4375)
Base wheel / Tire (F&R) 235/45 R18
Target Road Load A lbf 38.51
B lbf/mph ‐0.0811
C lbf/mph^2 0.01610
RLHP @ 50mph 9.95
Sub configuration # 1
33% Curb Mass (lbs) 3848
Loaded Vehicle Weight (lbs) 4148
Wheel / Tire 235/40 R19
Target Road Load A lbf 42.30
B lbf/mph ‐0.0212
C lbf/mph^2 0.01691
Road Load HP @ 50mph 11.13
This shows the coefficients from the coast down test and should be quite accurate to compare the wheel and tire combinations.
I calculated Wh/mile for 5 to 100 MPH using A, B, C coefficients and then divided 80,000 Wh by the result for the range at the given speed....
