That Ioniq battery is impressive! If they had a 60 kWh version, I'd really think about getting one instead of a Model 3 as our secondary car.
That's not how the battery chemistry and vehicle design works. The Ioniq's battery pack is apparently 272 kg (600 lbs) for a pack level specific energy of 114 Wh/kg. Scaled to 60 kWh, that's 544 kg, or 1,200 lbs which is the same as the Model S's original 85 kWh battery pack (2012) or 149 Wh/kg. The weight of car increases by 600 lbs and the volume of the pack dramatically affects the vehicle design. You can't just put double the pack size into the same car with the same chemistry without dramatic design alterations.
The trade off for much lower specific energy in the Ioniq's case is the ability to handle higher charging c-rate. Go for higher energy dense cells and the tolerance for higher charging c-rate drops unless some chemistry breakthrough is developed.
The Model 3's pack level specific energy is somewhere over 175 Wh/kg once you remove the components in the "penthouse" of the pack. Not only that, it has been proven to charge at a peak c-rate of 1.47 too. This is the most advanced automotive pack available.
Chances are the Porsche Taycan is going to sacrifice specific energy to achieve higher charging c-rate. That's probably a correct assumption that most people buying a Taycan aren't going to road trip the car anyways. So the cadence of driving and charging doesn't really matter. Right now, the Mission-E concept weighs about 2,500 kg or 5,500 lbs and they hope to achieve a weight target of 2,000 kg or 4,400 lbs. That's quite a bit of shaving of weight they still have to do and chances are they have to rely on newer generations of battery cell chemistry to achieve it. In comparison, the Tesla Model 3 Performance weighs in at just over 4,000 lbs, or almost 10% lighter than the Taycan's target for similar size and acceleration performance.
Both the I-Pace and the upcoming Audi E-tron demonstrate how far the major automakers have to come to match Tesla's engineering when it comes to BEVs. The pack level specific energy and the overall efficiencies are terrible with this new crop of vehicles. It appears that real competition won't arrive until well after 2020.
