Everytime I go for a quick grocery run (just myself, the driver), even leaving the FOB in the car, the car will shut down, leaving my family in a heated car. How do I prevent that? This has been annoying me and well, my family mostly.
You can just press e-brake and the car will put itself in neutral. Have used this to keep the car on for people as I've gone inside.Have a passenger touch the main display after your door closes. Or the hard way, put in Neutral and put e-break on.
Does that actually work? I was trying to figure out a 'camping mode' where you can be a a campground and charge overnight and sleep in the back. You can't use the e-brake trick because you can't charge with it in that state.Leave a large sack of potatoes on the driver's seat.
I have no clue. It was meant as a joke. It does remind me of this cartoon, though.Does that actually work? I was trying to figure out a 'camping mode' where you can be a a campground and charge overnight and sleep in the back. ...
I proposed (to Elon on Twitter) a "Hold Temperature" button that would pop up over the HVAC controls whenever the car was placed in park--- sort of like the garage door openers do when you're close to home-- that would hold the current set temperature for 30 minutes.
Not only would this be faster than triggering the app after you've left the car, but it would allow the car to maintain temp when NO ONE is in it while running errands in hot/cold weather. Generally speaking, for quick stops this should be more efficient than allowing the cabin to drift away from the preset temp and have to fight back when you return.
As expected... there was no response on Twitter. But there ya go--- an easily added piece of code that would benefit ALL Tesla owners, not just the newer Autopilot crowd.
Email with subject Feature Request to the [email protected] email and they forward to the appropriate teams.
I want to be able to stay at a campground as I travel some nights
I want to charge on the 50 amp NEMA 14-50 *and* sleep in the back of the X *with* the HVAC system running!!
