Started downloading as I was in the drive thru at Raising Cane's, debated whether to park after and wait in the car while it installs but then decided I'll just drive it tomorrow so I can eat my chicken while it's hot at home
Wow. Wow! I'm massively impressed with the 10.5 improvements and can't wait to test more during the daytime. Both the 2 above turns are consistently taken without much issue anymore probably due to "Improved static world predictions (road lines, edges, and lane connectivity) by up to 13% using a new static world auto-labeler and adding 165K auto-labeled videos."Main reason is probably because the perception is currently not good/sure enough until the vehicle gets closer with a better view of the turn. Theoretically the neural networks with more training should be able to make the prediction earlier and more confidently resulting in a smooth turn, but at least right now, it's actually very important that FSD Beta makes these "real time" jerky corrections to its path.
There's a left turn where FSD Beta 10.x doesn't see the destination past the median until it is in the middle of the intersection, so it actually starts the turn aiming towards oncoming traffic to the left of the median. Here's a Google Street View of the turn except it's from a higher vantage point, which I believe also helps the Y take the turn better than the 3:
Similarly, right turns can get confused by bike lanes and/or parking lanes such as this turn that has both (and wife actually messaged me complaining about this just yesterday ). And of course faded lines or those covered up by dirt/tire tracks are likely to confuse the perception:
Just took my initial drive on 10.5 and like many others have similarly said massive improvement. My early morning locate route (25 and 35 mph) is highly curved and there was virtually no phantom breaking, only a couple false turn singles on high curvature roads when in the past there were many, and only a few crossing the double yellow line. Most of these roads have no shoulders. Cross traffic was very limited but road turns were very smooth. A couple of occasional degraded camera warnings but no disengagement because of that. I am excited to try it out in traffic later and maybe not paranoid of being rear ended with, at least for these routes, phantom breaking almost gone or at least more obvious places where it will possibly occur.Wow. Wow! I'm massively impressed with the 10.5 improvements and can't wait to test more during the daytime. Both the 2 above turns are consistently taken without much issue anymore probably due to "Improved static world predictions (road lines, edges, and lane connectivity) by up to 13% using a new static world auto-labeler and adding 165K auto-labeled videos."
Overall visualizations are showing solid / confident lines and road edges ahead generally to the "vanishing edge" even at night, and I expect daytime driving to improve cross street visualization improvements with better visibility. These strong predictions from so far away probably allows for much better control with FSD Beta getting more seconds to plan instead of last-moment jerky reaction.
Huge congrats to the autolabeling folks!
Same issue here, car stays full left when stopped for right turn at intersection. Cars approaching from behind me pull alongside to make their right turn while mine sits there signaling.Quick drive. Mixed results
Good-
-Improved turning and lane alignment. Actually did a halfway decent turn into my street.Bad-
-Per usual came to a full stop entering the rotary. Once cars came up behind me I had to take over.-Construction zone with cones. Simple reduction to 1 lane for 100 feet. Instant panic by FSD and Immediately told me to take over.-@ T-intersection came to a full stop then crept and started to go. However once it realized it would go over the center line it stopped in the street.Better to stop then hit the traffic coming the other way. Since FSD won't point the car to the right as it approaches the intersection the car cannotmake the turn on my side of the road. Every driver when they approach this type of an intersection will turn the car to the right as it approachesthe intersection.
IMO the root cause is having to stay perpendicular to the road. If FSD turns toward the right the front camera cannot adequately see to the left since the B pillar camera cannot see properly with a partially obstructed left side. By staying perpendicular and needing to creep the car HAS to cross the center yellow line to make the right turn.Same issue here, car stays full left when stopped for right turn at intersection. Cars approaching from behind me pull alongside to make their right turn while mine sits there signaling.
In my case the car was not crossing the double yellow line. It stayed left and the road was wide enough that cars pulled up alongside me (still perpendicular to the cross road) to make their right turn. My car did not move right until it creeped into the intersection prior to turning.IMO the root cause is having to stay perpendicular to the road. If FSD turns toward the right the front camera cannot adequately see to the left since the B pillar camera cannot see properly with a partially obstructed left side. By staying perpendicular and needing to creep the car HAS to cross the center yellow line to make the right turn.
I don't see how Tesla solves this without a camera closer to the front. Perhaps Tesla will just have to identify this turn as problematic and reroute the drive.
I actually noticed improvement in this regard. When leaving my subdivision (stop sign intersection with trees obscuring the view) the car now angles slightly as it approaches the stop sign so it has a better view. Under 10.4, it would remain perpendicular then execute a hard 90 degree turn.IMO the root cause is having to stay perpendicular to the road. If FSD turns toward the right the front camera cannot adequately see to the left since the B pillar camera cannot see properly with a partially obstructed left side. By staying perpendicular and needing to creep the car HAS to cross the center yellow line to make the right turn.
- Starts slowing much sooner for stop lights (opposite of someone else's stop sign experience I couldn't find again, possibly on a previous page).
Stop sign experiences seem to be all over the board. I had it stop right where it theoretically should with a stop sign that is arguably too far from the intersection, but this was in a low speed subdivision. I also had it behave just like previous versions at another stop sign that is on a higher speed marked road. Others have indicated that it stops way before signs, and in one case someone indicated that it didn't get stopped until it was encroaching upon the crossing road.This is a good point. Stop light slowing is very nice. But stop SIGN slowing is really off. It slows too early, and takes forever to get to the stop sign.
Excellent. My problem is the B-pillar doesn't have a clear view to the left and IMO the only way FSD can see to the left is to stay perpendicular and creep but that requires a hard 90 degree turn. However there isn't enough road space to avoid crossing the center line and at this intersection FSD will proceed with traffic coming from the right and then has to stop in the road. When that happens I just have to take over early and do the turn myself.I actually noticed improvement in this regard. When leaving my subdivision (stop sign intersection with trees obscuring the view) the car now angles slightly as it approaches the stop sign so it has a better view. Under 10.4, it would remain perpendicular then execute a hard 90 degree turn.
