flyhighboi20
Well, it sounds to me like you are noticing the cold weather thing they did with the windows but this isn't new so I am not sure. In case you weren't aware, in sub freezing temps the car will keep the windows down just enough to clear the trim (window is still against the seal). The car will do this on doors that have been used recently (not sure the time frame for this) the car will then put them back up fully when you get back in. This is to help with the problem people were having of the windows being frozen in place and damaging the trim when people tried to open the door. If you already knew about this and you are talking about something else then I have no idea as this is the only thing my car does with different windows.Has anyone else noticed the windows and doors doing something extra on CLOSE… I know the windows come down on open, and go back up on close, this has been the case since inception really.. But, it seems that when I close the drivers door, either ALSO the passenger door and/or the other doors ALSO seem to do a window top up even though none of them had been opened prior. I can hear it in the car, and it is definitely new.
