The Model 3 has open differentials so it should be no problem.I was just wondering if there is any issue with using the compact spare thats a different width than the stock wheels? I know that cars with LSDs / AWD would have gear issues by running the wrong sizes but I didn't know if that was a real concern with electric motors...
I bought a Hyundai Genesis 18" spare on ebay for $100 with free shipping. I mounted it front and back and took a drive each time for a few miles. It works perfectly. The standard Tesla lug nuts fit the wheel just fine. The tire that comes on this spare is easily rated for the weight of the Model 3. Diameter is the same as tires that come on the 3. This mini spare takes up way less room in your trunk and weighs 15 pounds less than bringing along a full size Aero wheel and tire.
I would suggest only carrying a spare if you are going off to areas with little to no Tesla service and especially no cell service. I spend a fair amount of time on the Navajo and Hopi lands where one needs to be self sufficient. In most cases a plug kit and compressor is all you need but there is always the small chance of a complete blowout.
I recommend you buy one or two of these jack pads to carry with you along with a scissors jack and breaker bar with short extension and 21mm socket. My preferred: Jack Pad: Tesla
For charging you have Superchargers in Flagstaff, Holbrook, and Blanding. Destination charging in Tuba City. Gouldings, Monument Valley, and Tuba City have RV spaces with Nema 14-50. Fabulous La Posada Inn in Winslow has 80 amp Tesla chargers as well. In Bluff Ut, the wonderful Recapture Lodge of "The Monkey Wrench Gang" fame has 120 overnight and also in Bluff, the Twin Rocks Trading Post has two J1772 free chargers. With a long range Model 3, and even my previous S85, Navajo lands are pretty easy. When I visit friends at Hopi First Mesa, I always end up giving the folks rides in my car. Rumor has it Kayenta will have a Supercharger coming, it will be a perfect location. If you do not have the Plugshare app on your phone, I would highly recommend it.I’m originally from Navajo-Hopi land. Tuba City High School graduate (1988), and Rocky Ridge boarding school (elementary). Thanks for the info on the spare! I bought a mini Beemer replacement that works well, but cost double what you paid. Great find! Where can you charge up besides Holbrook? The distances on the Rez are so great. I’d like to take a Monument Valley trip with my kids over Christmas break.
Thank you for the great Rez charging info!For charging you have Superchargers in Flagstaff, Holbrook, and Blanding. Destination charging in Tuba City. Gouldings, Monument Valley, and Tuba City have RV spaces with Nema 14-50. Fabulous La Posada Inn in Winslow has 80 amp Tesla chargers as well. In Bluff Ut, the wonderful Recapture Lodge of "The Monkey Wrench Gang" fame has 120 overnight and also in Bluff, the Twin Rocks Trading Post has two J1772 free chargers. With a long range Model 3, and even my previous S85, Navajo lands are pretty easy. When I visit friends at Hopi First Mesa, I always end up giving the folks rides in my car. Rumor has it Kayenta will have a Supercharger coming, it will be a perfect location. If you do not have the Plugshare app on your phone, I would highly recommend it.
Hi John,
The specs you mention 10-16 and 10-18 I have no knowledge of. I simply bought on ebay: HYUNDAI GENESIS SEDAN OEM 18" 135/80/18 DONUT SPARE. Maybe someone else can comment.
In regard to the 10mm bolt securing the rotor to the hub, I simply carry a 10mm wrench to remove the bolt should I need to mount the spare. I have been a pro mechanic over 40 years. That 10mm bolt is not necessary, it is simply there for manufacture and service convenience so that if the wheels and calipers are removed, the rotor will not slip off. Once you bolt down a wheel to the hub in which the rotor is sandwiched between hub and wheel, that rotor ain't goin' nowhere! Most cars do not even have a rotor bolt nor screw.
Gene, Sorry for another question. I have seeing two different spare tires out on ebay: 135/80 R18 and 135/70 R18. Is one of these a better option or does it not make that big of a difference?Thanks Gene
I had a blowout on my Suburban this past weekend and called AAA. Their first question was “do you have a spare” I thought it was a weird question, but perhaps that is the way it is nowadays.It's not that Tesla feels it is unnecessary, it is just general trend across the whole industry. In the ever more increasing push for more fuel economy, carrying dead weight of spare and jack that may never be used was easy place to cut out weight. Most times the pump and tire sealant are just as adequate in a pinch without the weight penalty. Last time I had a vehicle with an actual spare tire was 2000 when I had a pickup truck. Every car since then just had pump and tire sealant and have never needed to use. I'm sure I just jinxed myself.
I only have my phone with me so its hard to look up. You need to get the specs for both tires, essentially the diameter. You can go to tirerack.com. Get the tire that is closest diameter to the stock tires on the Model 3. Too much differential between tire diameters may set off alarm bells on the Model 3. What's more, on any car, if you use different diameters on any drive axle you, at the least overwork the differential or, trick the car into thinking one wheel is spinning too fast and set into action traction control.
In my case, I have a RWD Model 3. On any RWD car or truck, if I was to have a rear flat, which is the drive axle, I would take a good tire off the front, move it to the rear, then put the spare up front where there is only a passive axle with, obviously, no differential nor traction control.
Diameter of 18" OEM tire = 235*0.45*2/25.4+18 = 26.33"
Diameter of 70 series spare = 135*0.7*2/25.4+18 = 25.44"
Diameter of 80 series spare = 135*0.8*2/25.4+18 = 26.50"
So, I would go with the 135/80-18 tire.
What’s that from? Specs please
I like this one for front and rear
Hi John,
