the 19” Tempest is about 9 lbs lighter each wheel than the 2021 heavier Arachnids. times 4, and then times the factor of 1.6 suggested by the engineering article for wheel difference (even a bigger factor for tire difference) yields a ~57 lbs static weight savings equivalent. lighter weight forged wheels will yield even more.
A recent Plaid record 1/4 mile run at 9.08 was driven by a 130lb woman to save about 50-60 lbs from the weight of the average guy (they had other weight savings too).
50 lbs alone probably gets somewhere between half a tenth and just under a tenth in the 1/4. Tesla Plaid Channel found close to a tenth in the 1/8th with the lighter 19”, although the driver may have been about 40lbs lighter too, so the two together might explain the tenth.
Remove 50 lbs 3 or 4 times (wheels, driver, backseat) and you get close to 8.x. in the 1/4
