In mine, it appeared to be some type of a contact problem with the pins in the connector. The Tesla end of my cord was replaced after the surface temperature of the coupling reached over 170 degrees, and it remains cool now.
So, I have a hum that I hear around 70mph, but I sort of wrote it off as road/tire noise. It's not extremely loud, but probably the loudest noise I can hear. How can I differentiate between road noise and this noise? Do you happen to have a recording of the noise that was fixed to compare?
It's an impression or the car is reliable but the external accessories are not !? 170 degrees is incredible, it means some adapters can be very dangerous and can get fire !!
I'm pretty sure 170 degrees is well below ignition temperature for the vast majority of materials on our planet.
Good question. I tried to record it with my phone but when I listen to it all I hear is road noise. So it seems to be a frequency difficult to record. However, it was so noisy that I had a hard time listen to the radio while driving at that speed. So I would suggest if it bothers you a lot to talk to your service center.
Well, I shifted into neutral while the noise was audible, and it did not go away. I presume this means I have just road noise. It does make me wonder about my alignment now...
As I told bareyb in person at NPID yesterday, the P85 Model S I test drove made the same "deflating balloon" sound the 2x I was able to hammer it. It's pretty noticeable.I think perhaps we are talking about two different things. Of course all electric motors "whine". The Balloon Squeal I am hearing in that recording is not normal... If I show up to get my car and it squeals like a pig every time I step on it, I'm going to leave my car at the factory and refuse delivery. I could not live with that. It sounds like the car is squeaking out a tiny fart...
Just so I'm sure you and I are on the same page... are you saying that THIS (see video below) is "normal" and happens on every single car with an electric motor? How do you explain all the people around here who don't have it?
I still remain concerned about how extremely HOT the HPWC handle got and am interested in HPWC owners' experiences charging at 80 amps.
Have you checked this thermal imaging thread?
I called into the Scottsdale service center to have a few things checked out (a rattle by the windshield, loud noise from suspension going over speed bumps, decreasing rated range etc). The other time I had it in they did valet pickup and drop off. This time they asked when I could bring it in and if I had another car I could use. Overloaded service center? The service center is 30 miles from work on the North edge of town.
Yes but if it's the external temperature, the internal temperature is higher. And it means there is a contact problem which can be worst with time, and can really get fireI'm pretty sure 170 degrees is well below ignition temperature for the vast majority of materials on our planet.
Hi,
I got my Model S few days ago. First thing I noticed was wind noise from the pano roof. I looked and it seems to be missing about 10cm (4 inches) of upper seal in the front middle part. Looks like it was cut out. Could you confirm it looks like that on all cars?
Hi,
They sold all the loaners. At least that's what I was told by the Queens SC.
Here's a photo: Dropbox - 2013-10-09 18.38.06.jpgUh, no. I've seen it folded under, but not "cut out". Can you open pano and snap a photo for us?
