Model X Range
Discussion in 'Model X: Driving Dynamics' started by EVger, Sep 13, 2015.
  1. Roamer
    Roamer Member
    Mesa, Arizona, United States
    That leg was run at 80 to 82 mph most of the run. Temps from 12 to 22 degrees. For part of the run I double tapped defrost to run everything on HI to clear the fog off all the windows as I drove thru some light fog. When I took the picture I had dropped to 75 mph because I was hitting patches of fog. Not bad but just decided to slow a little bit.
    I would say that run was the coldest and fastest of the entire trip. I knew I had plenty of range to make the Beaver SC so had no reason to baby it. Roads were clear and dry. I ate dinner at the Nephi SC so I had a higher charge than normal. Glad I had the higher charge.
    As a side note I am usually dealing with 100 to120 degree conditions in AZ. I don't do a great deal of cold weather driving anymore. I swear the Super Chargers really crank out the amps when it is that cold. I was getting higher amps for longer periods than I ever recall getting in Arizona in the summer.
  2. Roamer
    Roamer Member
    Final trip numbers
    These numbers are about as worst case as I could imagine.
    New tires
    600 miles loaded heavy
    Almost all miles run at 70 to 80 mph
    1500 miles in below freezing temps
    at least twenty test drives each with several Ludicrous full power runs.
    Lifetime (15,000 miles) on my P85D is 352 Wh/mi. 90% highway including running the same trip in the summer I just finished in the winter in the new X.
    I expect the X to average out a little higher than the P85D on staggered 21's. Based on my runs I anticipate for my Southwest freeway driving it will settle in between 355 and 365. My wife who will be primarily driving city will likely produce better numbers than my lead foot highway runs have produced.
    I will let you know in 12 months if I am close on my projection.
    Sorry I am not a detailed record keeper. To busy Roaming.
  3. Gzrgmr
    Gzrgmr Member
    Greenville, SC
    Thanks for the info. This is the best that I have seen on TMC so far. Just got notified for final payment and should be picking up mine soon. We have hills in SC but our weather is more moderate. I just hope that I can come close to your Wh/mi !
  4. Roamer
    Roamer Member
    Think about it before you get excited and make the final payment. I received the email on my Sig Order 594 VIN 8XX on Dec 12th. When I ordered model S cars that meant imminent delivery. So I just wired the funds. 30 days later and I still don't have a delivery date. A week later my lower reservation lower VIN car billed. Hope springs eternal and I wired the funds for that car also. Two weeks later that one delivered. So my experience is that, unlike buying an S, when buying an X getting the please pay email does not mean anything.
  5. Craig-Y
    Craig-Y Member
    Texas
    Roamer! Thanks for the great information and suggestions. I'm really looking forward to getting my X and I will do as you suggest until it learns my habits. Thanks again!
  6. vangogh
    vangogh Member
    Sunnyvale, Ca
    The X is my first Tesla and I'd like to get an idea of range reduction on different driving conditions.....
    I've seen on the forum how towing a 5000lb boat can reduce the range significantly...
    When I took a 75 mile trip with the same starting and finishing elevation it showed I had used close too 100 "miles" of battery charge.
    Conditions - No climate control, internet engaged, Autopilot (w/o ludicrous mode not engaged) at 65 almost the entire time w/o much traffic, light rain
    Can you let me know if this is normal for the S (or X if anyone has any information)...and how is % range impacted by the following based on windless flat 65mph driving
    Driving Speed + 10mph
    Driving Speed - 10mph
    Driving Speed - 30mph
    Headwind +10mph
    Tailwind +10mph
    Rain
    Elevation Change from start to finish over full range +1000 feet
    Elevation Change from start to finish over full range - 1000 feet
    Elevation Change from Start to finish over full range +5000 feet
    Elevation Change from start to finish over full range - 5000 feet
    Ludicrous acceleration
    Thanks
  7. scottf200
    scottf200 Active Member
    Chicagoland ModelX S603
    Model S Efficiency and Range | Tesla Motors
  8. vangogh
    vangogh Member
    Sunnyvale, Ca
    Thanks @scottf200...
    I'm going to need to continue to watch my range....
    Initial indications are noticably lower than the 250 range desired...
    could be new tires, cold weather, rain etc....but need more data
  9. CO2CLEAN
    CO2CLEAN Olivier Willemsen
    Netherlands
    If you would like to get around 250 miles of range, you need to get the energy consumption around 312 Wh/mile. If i'm not mistaken, i have read somewhere else on the forum that the 90 kWh battery has around 78 kWh of usable energy. The rest is buffer to prevent bricking and such.
  10. aesculus
    aesculus Still Trying to Figure This All Out
    Northern California
    I am new to the whole BEV/Tesla thing. I have heard of people needing to get towed in when they ran out of juice. This is the first I heard you can brick the car though.
  11. Vizir
    Vizir Member
    OK
    The battery is under warranty even if user error causes the damage.
  12. pvogel
    pvogel Member
    Santa Clara, CA
    You can't brick it. That's the point. 90kWh battery is considered 'discharged' to zero and the car stops and makes you get it towed after 78kWH usage, leaving about 15% capacity remaining. Warnings probably start at 25% capacity remaining or earlier depending on how far you are from available charge facilities.
    Discharging a Lithium battery to zero does permanent damage and significantly increases the internal resistance of the battery, reducing lifespan, reducing battery capacity prematurely and making the battery run hotter both when it is charged as well as discharged, increasing the power needed to keep the pack cooled.
    It's a very vicious cycle once begun. No competently designed EV or hybrid would allow the SOC on the battery to drop below 10% remaining.
    Peter+
  13. JRod0802
    JRod0802 Member
    Boston, MA
    #33 JRod0802, Jan 20, 2016
    Just thought I'd point out this Model S thread that has a lot of useful info. Maybe some crosses over to X:
    Putting some numbers on the factors that affect range
    Here's a graph that shows range vs speed both with and without the heater on (for the Model S):
    As you can see from the graph, if traveling at a constant 10mph, you actually spend roughly three times as much energy running the heater as you do driving the car. So that's interesting.
  14. dirkhh
    dirkhh Middle-aged Member
    Portland, OR, USA
    It boggles the mind that it is legal to advertise this as a 90kWh battery, though. That's like saying a car has 691hp when it only has 463hp. OK, bad example.
    That's like selling one gallon jugs of milk that only allow you to pour out 111oz. A 12-pack of eggs with only 10.4 eggs. A six pack of beer with 5.2 bottles.
    As a consumer, if I buy a 90kWh car I think it's a reasonable assumption that the battery (at least when new) can deliver between 89.5 and 90.4 kWh.
  15. CO2CLEAN
    Netherlands
    #35 CO2CLEAN, Jan 21, 2016
    I disagree, since you cannot (without damaging) deplete the battery. That is considered common knowledge. However i do think it would be a good idea for Tesla to communicate more details about the battery and its characteristics. For example: explaining that not all the battery capacity can be used and why this has a positive effect on the battery degradation (in that the degradation is less).
    EDIT:
    Just like it is bad to drive the gastank emtpy. It is possible, but has a negative effect on the engine (some sludge from the bottom of the tank will get in the engine). There is no protection for gasoline/diesel cars.
    That is why we have the range tests from the EPA that will provide some insight in the range that is possible with the battery. Just like with gasoline/diesel cars however these tests are too optimistic.
  16. McRat
    McRat Well-Known Member
    LA
    If you take apart an EV battery, and count the cells and record the wH, that's the size. That's how much battery you purchased. Range is what you are actually looking for though.
    Think of it like claiming a car has 400HP but when you put it on a chassis dyno, it only shows 350rwhp. Did the mfr lie? No. Actually, the engine is probably more than 400HP in reality per SAE method.
    There are advantages of having a larger battery that aren't always obviously. It can handle higher discharge rates, and higher charge rates. It will have more "miles" available before replacement.
    Example:
    Let's say you want 50kWh usable. You have two packs with the same cells, one has more cells though. One pack is comprised of 75kWh of cells the other 60kWh of cells. The 75kWh battery is capable of 25% more HP output, and 25% more amps at charging (25% faster). The 75kWh will normally last 25% more miles.
    If you advertise both cars at 50 kWh, it's not the whole story of what you're buying.
  17. vandacca
    vandacca ReActive Member
    Hamilton
    Maybe it's more like buying a 64Gig Phone, where only 52.8Gig are free to the user and the rest is for the OS?
  18. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    A 50 amp circuit...
  19. aesculus
    Northern California
    I think this is exactly that. But they should state the useful wattage. Aircraft have a similar issue. They carry so much fuel but a lesser amount is actually useful (ie it will get to the engine).
  20. dwebb66
    dwebb66 Member
    Ladera Ranch, CA
    How many people a) can or b) would care to convert the battery size (max or actual usable) into something that would have meaning in their daily lives?
    for example Charging time or Range
    Using the 'marketing' number is fine for me.
