Probably, Can’t really comment on sound levels I always listen to music when I drive.I have noticed that it keeps the interior sound level down.
For those still dismissing the higher voltage video without actually watching it, The Limiting Factor seems to agree with it:
A far simpler explanation is that the base pack is 828 cells and puts out 70 KWH, with a future option of a LR pack at around 966 and presto 82 KWH.
The need to invent a never-seen, never-EPA-tested 3rd smaller pack fails Occam's Razor for me. It's a much more complicated explanation when there's a very simple one standing right there.
But you saying that it takes 828 cells to make ~68 kWh doesn't match with what Tesla claims for the cells. (They claim 5x the energy of 2170s, which are ~18 Wh.) So the ~90 wH per 4680 cell lines up pretty well with what Tesla has shared.
If you are correct and it takes 828 cells for ~68 kWh would mean that Tesla has failed pretty badly on their 4680 plans.
The Fremont paint shop is a *sugar* show...
Suffice it to say, upgrading the paint shop would cause months of downtime that Tesla can't afford, so it doesn't really get touched in Fremont. Might in the future when Tesla has spare capacity and can take that facility offline for a major rework, but the paint shop is not a quick and easy upgrade.
The 2170 cells chemistry have a higher power density, hence better performance. 4680 have less power density/energy, therefore less performance. However, the trade off is the 4680 batteries are lighter and can be charged to full more routinely.Stunningly good, best I have seen yet on topic. Sadly does not improve our chances of getting a further develop model Y performance any time soon.
I could be wrong, but based on what I've heard 2170 and 4680 have similar chemistry (not iron) and have the same issues with increased degradation when fully charged.The 2170 cells chemistry have a higher power density, hence better performance. 4680 have less power density/energy, therefore less performance. However, the trade off is the 4680 batteries are lighter and can be charged to full more routinely.
The 2170s have higher lithium content, while the 4680s have higher nickel content. The 4680s have 5X more energy than a single 2170 cell but 4680s are also 5x larger. 2170s are more energy dense due to chemistry which is also why they are heavier.I could be wrong, but based on what I've heard 2170 and 4680 have similar chemistry (not iron) and have the same issues with increased degradation when fully charged.
Clever marketing by Tesla to say 4680s have 5x more energy while omitting they are larger and less powerful cells.
Hence the performance/acceleration is less in the 4680 model Ys.
The pack size primarily only affects range. Performance is generally the same weather you have 70% charge or 100% excluding significantly low states of charge.The performance drop is almost certainly because it just a smaller pack.
Given the continuous-tab design of the 4680, I'd expect it to eventually handle a bit more current (and thus power) than similar-size 2170 pack.
Relatively speaking the power difference is minimal but still noticeable.
The cells Tesla was making at the time did not have as much energy today. The original 2170s had ~16.9 Wh/cell. * 828, you get 70kWh. Throw in a couple rounding errors, and 68kWh from 828 cells is in line with those claims.But you saying that it takes 828 cells to make ~68 kWh doesn't match with what Tesla claims for the cells. (They claim 5x the energy of 2170s, which are ~18 Wh.) So the ~90 wH per 4680 cell lines up pretty well with what Tesla has shared.
It’s called sarcastic exaggeration
Tesla's own battery day presentation says you are . . . well just flat out wrong.
5X the energy, but 6X the power.
Makes sense from a "first principles" reasoning as well. 2170 is a wet battery electrode chemistry. Gotta have space for that solvent. 4680 is a dry battery electrode, so the "jelly roll" as it is called can be wound more tightly, and therefore it is more dense.
Remember battery day was more than 1.5 years ago and at that point 4680 cells were still in the R&D phase. The production 4680 cells may differ from what was anticipated back then, due to cost or manufacturing constraints. Therefore. any numbers/claims made back then as to performance may simply no longer be valid. At this point we really do not know what is the performance of the actual production 4680 cells.Tesla's own battery day presentation says you are . . . well just flat out wrong.
It's not 5x more energy dense, it stores 5x more total energy (due to being 5x larger).
The larger diameter is less space-efficient, which they're making up for with improved details in the cell construction as you note.
The 6x power is a slight improvement - very likely from the continuous-tab making lower resistive losses in the cell.
I didn't say 5X more energy dense. I just said 5x the power (yep, volume is 5X bigger than a 2170), and 6X the power.
