That’s a reasonable concern. You don’t see many pickups actually towing stuff... maybe I dunno, one mile out of every 500 across all trucks on the road? But if youre a boat person it's real and you need it to deliver more than 80 miles of range dragging a 26-foot center console or whatever.
EPA range quirks from one manufacturer to another aside, there doesn’t seem to be a whole lot of magic left out there... no 50 percent improvements in efficiency/range on the horizon.
All the casting in the world is only going to shave a couple of hundred pounds from a vehicle at most... so increasing the use of castings isn’t a grail, except for manufacturing speed and labor cost. That’s where it’s genius, not in adding magical performance to a vehicle. And at some point, casting is too much. A cast door would likely be heavier than current type.
In truth, going the other direction -- tedious amounts of labor building a full carbon fiber chassis -- would be the ultimate performance gain for handling and acceleration at least, but wouldn’t do much for range at 70 mph. And would be totally impractical to mass produce.
And batteries... the 4680 form factor even at best is only going to yield tiny improvements in the amount of power stored per pound, as it is essentially just a larger version of the current battery in terms of chemistry (I’m simplyfiyign the we vs dry thing]. The battery would have to be radically different to yield a 500 mile CT at a reasonable weight. Never mind a 600 mile roadster that any reasonable person would expect to handle like a sportscar.
