Finally got my set of front rotors from @MountainPass and wanted to share some details and pictures. Quick install guide is after the pics...
They are beautiful, so it's a shame I've got to install them to just dirty them up, but I wouldn't have it any other way
Details:
Stock P3D+ rotors (@ 5K miles)
Diameter: 14"
Thickness: 0.985" thick
Rotor hat thickness: 0.10"
Friction surface width: 2.44"
Weight: 19.4lbs
Function: Performed well on the track with upgraded MPP SS brake lines and Motul fluid
Form: Meh, but better than non performance
MPP P3D+ rotors
Diameter: 14"
Thickness: 1.03"
Rotor hat thickness: 0.297"
Friction surface width: 2.43"
Weight: 18.2lbs
Function: TBD on 3/31 at Buttonwillow (Tesla Corsa 3)
Form:
Comparison photo:
Sans caliper:
With caliper:
As most folks know, you don't do a whole lot of traditional braking with the car if you've got regen on standard. However, I have taken a few drives with regen on low, and have enjoyed braking with these. But since I'm a responsible driver, and follow the speed limits... it was not possible for me to notice any major difference in braking on the streets. There is no additional noticeable noise. (Or I never listened closely enough before to notice whether these are louder or not).
Installation was straight forward (note, this is a guide, so follow at your own risk) -
Details:
Diameter: 14"
Weight: 19.4lbs
MPP P3D+ rotors
Diameter: 14"
Thickness: 1.03"
Weight: 18.2lbs
Form:
Comparison photo:
Sans caliper:
With caliper:
- Lift, and properly support vehicle.
- Remove wheel.
- Use an inverse torx socket (E18), and remove the 2 bolts holding the caliper
- Remove the outer brake pad, and then remove the mechanical wear sensor (cut it off, or bend until it breaks)
- Reinstall the pad
- Support caliper with something, or tie it up
- Remove the 10mm bolt securing the stock rotor, and then remove the rotor
- Slip on the new gorgeous rotor, and temporarily secure it with a minimum 2-3 lug nuts
- Compress the brake pads until the caliper fits over the new rotor
- Be sure to open up the brake fluid reservoir for this step. (I forgot at first...)
- Reinstall the caliper, and torque the torx bolts appropriately
- Reinstall the wheel
- Repeat for the other side
- Marvel at your handy work
- Follow a proper bedding procedure
- Marvel at your handy work again
