Congratulations !!Picked up my car and it looked great. Pickup process was pretty easy. I arrived 1 hour early and they told me my car was ready. It was snowing and heavy winds at time of pickup however the car looked amazing! Panel gaps looked really good. Here are the only things that need to get addressed.
-usb port in the glove box doesn’t seem to detect thumb drive. I am not able to format drive from car and it says to insert a thumb drive to format.
-the wheel alignment is slightly off. (My wife’s model 3 pickup was more obvious). When steering wheel is straight the car pull slightly to the left.
-rear passenger door makes a different sound when closing compaired to other doors (I’m sure it’s a tightening of a bolt or something.
-slight panel gap in the rear where roof connect to trunk. One side is wider.
So I have a mobile appt. Coming up to install my purchased winter wheel/tire from Tesla and I’ll ask them. Hopefully the USB port works and the door can get resolved. I’d have to book another appointment for the alignment and will ask if the gap will cause an issue. If not I’m not concerned.
Really nice car!! I opt for the Tesla mud flats and they fit great. As for the ppf for the rear sides, I got the Tesla one and install was a super easy. I used a little baby soap and water and it looks great. Congrats on your car, it looks great!Picked mine up Friday 03/18/22 very happy with my purchase. Popped on my front A-Premium Amazon mud flaps before leaving the dealership and the rears when I got home. I am installing DIY PPF small pre-cut pieces on the rocker panels in front of the rear wheels this weekend along with black Tesila emblems and DIY Ceramic Coat. This thing is a beast. It is hard getting anything done. Word spreads fast and everyone wants to check out the car.
Even when I called the Princeton Tesla location direct in order to let them know IM was running late for a test drive, my call simply went to an automated system and I was placed on hold.Does anyone have direct number/extension to Springfield delivery center?
You may try: 973-921-0925. This number worked for us last time. Good luck.Does anyone have direct number/extension to Springfield delivery center?
Thank you, it connects you to a call center now. before you could select the store. now its all call centersYou may try: 973-921-0925. This number worked for us last time. Good luck.
When I called that number for service there was an option to be connected to the local service center. There it connected me to their service center.Thank you, it connects you to a call center now. before you could select the store. now its all call centers
My delivery date also changed this morning from May 31st to June 28th to June 25th to Aug 6th. I have no problem with the change. After all it is only another week. The Austin Factory is scheduled to open in April. I believe there are still part shortages and other issues in opening a new factory.EDD just changed this morning again. It went for April May to June July now July August. OD 9/11, I can’t do this anymore. That’s a year from my OD
Adding FSD seems to be moving dates closer. I got 04/25 window 4 days after I added on 04/11 and got VIN assigned. I just got a text to schedule pickup from lawrenceville.My EDD just changed again this morning from May June to July August. Any idea if changing the order now to a performance would increase the chances of delivery? I am in need of the vehicle before the end of May. This is not good....
Were you able to remove it once you were assigned a Vin?Adding FSD seems to be moving dates closer. I got 04/25 window 4 days after I added on 04/11 and got VIN assigned. I just got a text to schedule pickup from lawrenceville.
OD 10/17, Blue white/black with FSD added on 04:11
I didn't try that as I wantedWere you able to remove it once you were assigned a Vin?
I would even gladly take the Texas standard range but I have no idea what's going on anymore with east coast delivery timingsI didn't try that as I wanted
Most of the P MY orders fill faster than the LR AWD orders for the past year. See the spreadsheet.My EDD just changed again this morning from May June to July August. Any idea if changing the order now to a performance would increase the chances of delivery? I am in need of the vehicle before the end of May. This is not good....
