That also applies to 95% of the posts on these forums where a search or RTFM appliesLiterally 95% of this thread is in the FAQ's on the IO webpage...
Why do you want to switch to intelligent now then. Surely the tariff you are on is a lot cheaper?April 23 :/
If the app gives slots in advance I can see some tactical 1kwh charges to get more prime time off peak..
It's all good. Sorry, I should have been more explicit and less terse.Ok no problem.
Youād just said in your original post about looking at your link wouldāve given us the answerās. (Answerās rather than answer, as in more than one question.) As the other person had only asked one question, I thought you were referring to both of us.
Anyway, apologies if you didnāt mean it that way.
Main thing is that some good points have come out regarding IO, so everyoneās a winner.
I guess it was a typo and you meant April 22 not 23?Partly I got spooked by the email telling me Iād move to a new tariff and their website quoting me thwir fixed tariff at Ā£335 per month!
Also Iād rather fix now than risk the tariff changing last minute I guess.
Mines April 30th. Some people are still getting the go faster rates rolled over by the way. They have stopped the Go ones though.I think it mean April 23rd as its 45 days before it expires they're supposed to notify you
Have you had your renewal email yet? If not you might have slipped through the net and get your current rates for another year.
@Kansalis you might want to chance your arm and keep quiet. There is an active thread on the Octopus forums now which seems to be suggesting that although Go renewals were fixed to stop people rolling on to their old rates, Go Faster wasn't necessarily fixed and people have been renewing on their old tariff.
they take your travel data as wellI think they already know where I live
I last needed a charge on Sunday so the car has been unplugged ever since & temporarily disconnected via the IO app. I probably won't need a smart charge for a few more days & IO can be used as often or as little as required.does it require the tesla plugged in every night (I only charge twice a week)? or you just set a limit like 80% and plug it in when you need to? Depending how control freaky they want to be they may prefer smaller regular topups to give timing flexibility rather than me waiting until 30% to plug in and it needing more time.
And surprised you're allowed to just plug in another car as you're not timeshifting/demand shaping that one which is the point of the tariff. If octopus don't mind it maybe helps them research and get investment on demand shaping just from the tesla fleet for now
As for our other EV, it is only used locally, rarely needing more than an hour or two of charging & mostly on its own but occasionally at the same time as the Tesla. It has a 7 day schedule set to 23.30-05.30 which I disable whenever there is excess solar and the Tesla is already at its desired SOC (otherwise, plugging in causes the charge to always commence at 23.30 via either Zappi or granny lead).
Quick question on the various methods of restricting the total charge the car can take. There are settings within the car and also within IO. I assume the car overrides IO? So if car set to 80% and IO to 90% then the car would stop the charge at 80%?
similarly if I need 100% for a long journey I assume I need to set the car AND IO to 100%?
cheers,
greg
It will recalculate. In fact, you'll often find that it will recalculate its original schedule two or even three times through the early evening, as mine did tonight.I plugged in today at about 5:30 with about 23% battery. It gave me a schedule to get to 80% mostly starting at 11:30 then on/off through the night finishing at 7:30. Fine.
I then unplugged and had to go pick up my daughter. Will it recalibrate the time needed based on my now lower state of charge, or will it just give me the slots its calculated and maybe itāll be fine?
Not urgent, just curious
