I believe the Part Number is the "1014114-00-A." So, I believe you have an "A" battery pack.
I would think so too. My part number has the same A at the end. TM confirmed I have a battery limited to 90kw charging
I though so, but was wondering what that 1011721-00-B meant on the left side of the label under the 400V 85 kWHr description meant?
The small part number in the lower left corner of the sticker (under where it says 85 kWh) is a part number for the actual sticker.
Well, I guess that makes sense, but is hilarious nonetheless. I wonder if the backing you peel off the sticker has its own part number as well :smile:
Do the P85+s all have 120kW charging? Or is it possible they're on A batteries as well?
The earliest P85+ in the Battery Wiki Table is from July 2013 and has a B battery. People just need to add their battery info, its easy to do.
Battery table - Tesla Motors Club - Enthusiasts & Owners Forum
Any U.S. market signature that has the Plus retrofit has an A battery. But I suspect that's not what you meant.Do the P85+s all have 120kW charging? Or is it possible they're on A batteries as well?
There is one Sig + retrofit up in Washington State as well.
did they also have an A battery 'break' the negative contactor?
I have a Signature P85+ (Retrofitted) car with a 'B' pack (had a pack failure awhile back and Tesla put a 'B' pack in). Just did my first Supercharge since the retrofit and pack replacement. Here is what it looks like:
