3.2/2.7 = 19% more power at all speeds 0-60. It could also be done with more torque and no increase in peak power.Any experts wanna take a stab at how much more power P3D would need to put down to get to 2.7 consistently?
Someone should calculate the necessary tail wind! It would probably be a few hundred mph.such as a strong tail-wind
Your antic's of repeatedly claiming these times with absolutely no evidence to back it up are getting old lol.
Pardon my french but you should put up or...you know, stop talking about it? I'd put money on it that you couldn't achieve that time using a Dragy device with a validated performance report (meaning within slope tolerance the app accepts to post your time to the leaderboards) in a stock P3. But quite frankly, I don't see you doing that for obvious reasons.
I'm not claiming it's impossible but either the testing method is flawed or there is an external cause to be achieving that time - such as a strong tail-wind and/or a negative slope and/or weight reductions. Not all tracks are made equal.
.02 faster than this guy? impossible right?
tesla "model 3" 0-60 2.8 seconds - Bing video
Tesla Model 3 Performance's 0-60 mph acceleration dips below 3 seconds after software update - Electrek
He sees Tesla getting the Model 3 to a 0-60 mph launch in 2.8 seconds.
"He sees Tesla getting the Model 3 to a 0-60 mph launch in 2.8 seconds."
you mean down from 2.9 consistently?
lol @Knightshade disagrees with a post that isn't even about me.
It doesn't get any better than this.
.2 faster than this guy? impossible right?
Maybe its because I removed the 5 quarters from my console and he didn't. LOL.....
you guys really think that you are getting to me....that's hilarious.
Max power is more than 340kW. Good luck consistently measuring the effect of the heater. Even if you could not measure a difference it wouldn’t prove anything. The power limit is purely software, they might not even cut power to compensate for heater usage because it’s so insignificant. Max power draw from the battery is probably many megawatts if you don’t care about it catching on fire.Wow you guys got the magnetic flux too? Fun!!
So here are some test you guys can do.
1: turn off everything in the car and launch it. See what time you get
2; so the same launch, max out your heat.
Same 0-60 means it’s not battery limited.
3: turn on Dyno mode , launch it
Dyno mode is able to launch it faster, it’s traction control limited.
If it’s not battery or traction, then you are left with motor or inverter.
Now for power electronics the inverter can handle more power when they are kept cool. Transistor that’s used as a switch is in saturation mode, which means the channel has a pinch off reason, limiting the current flow. That can be seen as the max current. This current should save regardless of the toggle frequency. So that transistor on the buck converter should be able to transfer the same power at virtually all frequency range ( motor rpm). So lower power at lower motor rpm probably isn’t limited by the inverter.
I didn’t work with buck converter since my third year university. Anyone know if what I said is right? Feel free to correct me.
So If it’s not battery or traction control, and I believe is probably not inverter, that leaves it to be the motor. Motor design is out of my scope. Anyone know if motor efficiencies are affected by rpm??
One more thing
engineers evaluate their life span using the activation energy equation. Essentially it’s an exponential relationship. In general, 1 celcius increase in temperature shortens the life for 10x. 1 volt increase shortens the life by 10x. I’m not pulling out numbers from my thin air, I was a electronic process engineer before and that’s what 65nm tech data showed me.
to those who’s willing to sacrifice reliability, if the life time of the car is shortened exponentially, you probably don’t want the performance increase that pushes the electronics to its limit.
Of course that also requires an increase in torque for all the initial increases in power.3.2/2.7 = 19% more power at all speeds 0-60....
This is the more interesting question:. How much performance and cooling headroom is in that rear PMSR motor? It would take amazing hacking skills to run the motor solo on the bench to test. And to put it in the car you would also have to reverse engineer the private key that signs the controller code....It could also be done with more torque and no increase in peak power...
It's hard to get to someone who doubles down on what they're saying but can't provide any evidence. Now that's an argument I can get behind.
I've said this to you before but I'll say it again - @Zerosport has the fastest documented time I've seen of 2.74 seconds (1 foot rollout) and that's after removing 400+ pounds. You are claiming to hit essentially the same time as him while being 400+ pounds heavier.
Where is best to start shedding weight while keeping stock look? I’m starting with wheels which should help with nearly 50lb overall.For context that was prior to the November firmware power boost. Though we were on pirelli pzero racing tires (not as good as drag tires, but better than street.) Need to run the test again when the car is put back together.
Well. Stock on the surface. Not looking to remove seats or any interior bits.Totally stock? 12v battery is probably your best bet. @MountainPass makes a kit that shaves 20+ pounds and you'll never see it under the front trunk. For 0-60 performance like in this thread I'd say aftermarket wheels, rotors, and tires. You can shave a fair amount of rotating mass.
Am no expert but I'll take a stab.Any experts wanna take a stab at how much... to get to 2.7 consistently?
...Someone should calculate the necessary tail wind! It would probably be a few hundred mph.
