Yep.Looks like a toe issue
My 23 Plaid was around n good way to kill the rear tyres a while after delivery.
I did a wheel alignment with on numbers specified (n2itives). No mod, so stock high negative camber. But the toe is set to 0.15 degree per side, 0.30 total.
The stock 21” has not gotten worse, and from the alignment the surface temp on the wheels are about the same, only slightly warmer inside. Before they was a lot warmer (car hade toe put from factory in ”low”
My other 20” low rolling resistance setup wears perfect so far. Only around 1 K miles yet, but they really wear even.
