This seems to be a 1MWh battery, charging to 80% (800kwh) takes 30 mins. So the charger needs to put out 1.6MWh, more than triple of what you were guessing, no?The new megacharger will easily deliver at least 500 kw (maybe more) of electric power to the Semi-truck. But the real question is should the megacharger be compatible with Model S and X? What's your opinion?
Yes, you are right. The charge rate should be much higher than 500 kw. It was just my wild guess.This seems to be a 1MWh battery, charging to 80% (800kwh) takes 30 mins. So the charger needs to put out 1.6MWh, more than triple of what you were guessing, no?
That also makes the question: Should I be able to charge my S/X/3 with this pretty clear. For the next few years you would pop all wiring in a normal car in an instant/turn your car in a smoldering heap of metal.
I actually wish there was a button in the UI that you can choose “Mega” or “Super” charge. There are times where I actually don’t mind the hour wait, because by the time you eat and use the restroom and etc, it flys by.
Then there are times where I’d love to charge in 5-10 mins and go.
I’d choose “Super” for a slower charge and thus avoiding idle fees. “Mega” if I’m ready to get going right away, no bathroom break needed or anything.
That's why I stated the question if we "should". The reason for this thread is for discussion of the possibility.It's physically incompatible and I'm not even sure why you even made the thread.
The only way a S/X can use it is if they get the new connector and 4 battery packs. Not going to happen.
In case you haven't seen the connector see
it's like 4 charging cables in one port (2 pins per pack, 4 packs)
The question here was: Should one be able to charge an S/X/3 on a Megacharger and the Answer for the foreseeable future is a resounding NO! because there is no way those in comparison small batteries can handle roughly 10x the max current being pumped into them. Let me paint an overly drastic picture of what might result
Maybe not megacharging, but the consumer cars do need faster charging.
Months ago, there was talk about the possibility of reducing Supercharging times to 5-10 minutes, which would put a charging stop at about the length of an ICE stop at a gas station.
We've done several road trips with our S 100D, and want to stop every 3-4 hours anyway (bathroom/food/drink/stretching break). And if those stops could be shortened to 5-10 minutes each, the driving time would get close to what we would have done in an ICE.
