SolarCity is quoting me $650 for an outlet within 40 feet of the main breaker. I live in San Jose, CA. Can I do better? I tried to ask details from SolarCity, but they told me I'd get details from them after I signed. I asked if they were using conduit or bare Romex inside the garage. What's better? I think bare Romex along a garage wall probably looks better than conduit?
I also asked if they were going to run a wire from the main panel outside into the subpanel in the garage using existing conduit, or if they were going to run new conduit from the main panel outside directly to the outlet. Again, no answer.
Lastly, I asked about getting a 2nd outlet in the garage in case I wind up with two electric vehicles at some point. They didn't seem that interested, and said the price would be double for two outlets. How much more do you think it should cost to add a 2nd outlet?
How long does the install take? If parts are less than $200, I'm wondering how the price gets up to $650. I was thinking the work could be done in less than 3 hours.
Lastly, should I put the outlet on the door side of the garage or the house side of the garage? I think it's common to put it on the house side, but if the charge port is at the back of the car, wouldn't it be better to put the outlet next to the garage door?
thoughts?
Derek
Here are my thoughts, in the order that they came to me:
I'm assuming you're talking about a NEMA 14-50R.
NM-B cable ("Romex") may be used where it is suitably protected from damage (methods in NEC article 334) but exposed Romex cannot be used where it is subject to physical damage. In general, most inspectors will call out exposed Romex below 7' as a safety concern. It should either be within a wall or a suitable conduit if it terminates below 7' above the floor.
As to whether they'd feed this circuit from the main or the subpanel in the garage, it would depend upon the size of the feeder and the current loads on the subpanel. It's much easier for a shorter run.
As for what looks better, my garage wall is a chipboard surface with schedule 40 PVC surface mounted and it looks fine. If you have drywall in the garage, PVC conduit on the surface looks fine, especially if you paint the conduit hold-downs. It's all subjective.
For 2 outlets, if you want the full current, nothing can be shared -- you'll need a new breaker, new wiring, new outlet, and new conduit (unless you want to run extremely large conduit to run 2 sets of wires). So 2x cost is appropriate.
My outlet is mounted on the door-side, to the left of the bay it is intended to service, because that's where many of the ports are being placed. The Leaf uses the front, though. So basically, "it depends."
Finally, as for $650 for a 40' circuit length: I believe that to be a reasonable price, whether Romex or THHN, because it'll either be labor costs (fishing through a wall to protect it) or conduit & fittings.
