Really need help cleaning screen and dusting the dash
Discussion in 'Model S: Interior & Exterior' started by jomo25, Aug 2, 2013.
  1. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Is there a way to really turn the screen off so that you can dust the dash and clean the screens? If not, there really needs to be a way. I use a high quality microfiber towel and any time i get any where near the screen, it registers a bunch of touches on the screen. And then I use a monitor wipe to clean the screens, same thing because its still sensing touches.
    I read somewhere that there may be a fix to the static issue (establishing a proper ground behind the dash, done by service center). If so, I guess I look into that when I do take the car in for any service issues. Though this is beginning to be annoying enough to warrant it own trip. BUt that still wont address the screen touches when cleaning it.
    The "Car Off" mode needs to really keep the car off unless the brake is pressed IMO.
    I'm surprised this isnt a bigger issue for everyone else out there. The screen by nature gets lots of finger prints and dust, and requires frequent cleaning.
    Or am I just missing something?
  2. Todd Burch
    Todd Burch Voltage makes me tingle.
    Smithfield, VA
    I fold my microfiber cloth over several times and, while not perfect, it helps quite a bit.
  3. Merrill
    Merrill Active Member
    Sonoma, California
    If you sit in the passengers seat and close the door, everything will shut down and then you can clean the screen.
  4. jomo25
    Scottsdale, AZ
    Won't it turn on even if in the passenger seat if I have the fob?
  5. Merrill
    Sonoma, California
    We have done this several times, my wife will stay in the car with her fob in her purse and I leave to run an errand. I leave with my fob and once everything shuts down she will clean the screen and it does not come back on when you touch it.
  6. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    Don't worry too hard... I understand Tesla will be releasing a fix to this issue within a month or two :wink:
  7. mknox
    mknox Well-Known Member
    Toronto, ON
    Oddly, I've had no issue in this regard. I just use a small 4" x 4" or so microfiber cloth I got at Best Buy (meant for phones or tablets) and it works perfectly with no need to even fold over once. I've never seen false "touch" registers on the screen. I use something called a "California Dash Duster" to clean the dust off the top of the dash and other surfaces. Again, works perfectly and no problems with the screens.
  8. AC1K
    AC1K Member
    Calgary Alberta Canada
    what MS owners really need is a oleophobic screen protector (Zagg, ghost armor, some type of self healing eurathane type layer)
    im going to look around and try and get one custom cut
  9. phat78boy
    phat78boy Member
    Phoenix, AZ
  10. Jason S
    Jason S Model S Sig Perf (P85)
    Rocklin, CA
    Didn't know anybody packaged one of those yet. Nice to see!
  11. HHHH
    HHHH Member
    Henderson, NV
  12. JohnnyMac
    JohnnyMac Member
    Silicon Valley, CA
    Odly enough, I can clean my touchscreen at will with a folded over microfiber cloth and no issues whatsoever. BUT, god forbid I wipe the top of the dash in any location. If I do, the touchscreen freaks out and the seat heaters turn on, along with the front and rear defroster and the temp changes to something crazy hi or low. It appears to have a mind of it's own.
  13. lloyds
    lloyds Active Member
    Bay Area
    Any solution to cleaning the screen w/o turning it once the towel touches it? I tried looking through the settings, but can't find anyway to turn it off. I even tried taking my key and placing it inside the house, but the screen still turns on once it sense touch.
  14. EdA
    EdA Model S P-2540
    Massachusetts
    Reboot the computer and clean it while it is rebooting :)
  15. Jason
    Jason Member
    DFW, TX
    I only need to clean it about 1 a week so this seems like a great way to do it - Thanks!
  16. irishstoutaz
    irishstoutaz Member
    Cave Creek, AZ
    I have posted before but there is a very simple solution... just hold a fingertip at the halfway point on the left or right side and wipe away (I use a micro fiber cloth without any solution/spray and works great). The fingertip prevents anything else from occurring while you are wiping.
  17. Teriyaki88
    Teriyaki88 Member
    San Diego, CA
    I use one of those small pieces of soft cloth I got with my sunglasses. It works great. I keep it under the screen in the cubby hole.
  18. RandyS
    RandyS Fan of Elon
    San Diego
  19. Btrflyl8e
    Btrflyl8e Supporting Member
    Seminole, Florida, United States
    I've had no problems sitting in the passenger seat with the door closed. Even with the fob in my pocket my screen stays off while I clean with a microfiber cloth.
  20. JPP
    JPP Active Member
    SF Bay Area, CA
    ...stay tuned for v. 5 of firmware which has a screen cleaning mode...
