They moved it on AWD version.I know they moved the 12v on the S at some point. My early 2013 is a pain to get to.
Found on Facebook, not much more info unfortunately.
New bumper on "old" S, unclear if that requires a new hood or not.
Pretty certain you'll be looking at both a new bumper and hood. The new hood looks to have less of a curve than the old style, and definitely extends a little further forward.
I'm really ok with the look of the original design still. I am hoping however, that they at least make the headlight upgrade an option.
I might be interested in a headlight upgrade, if it's possible, but only if tests reveal the LEDs are superior to the best HID, not the stock HIDS on the Model S, which are quite mediocre, but upgraded HIDs of the kind ucsbwsr is planning to do. Otherwise the LEDs will definitely not be worth it.
Yep, same here! I came from a car with incandescent headlights (about as bright as the DRLs on Model S) from a 2001 car. The Xenons have been wonderful, it's scary driving my old Lexus now. But I would be interested in an LED retrofit if it doesn't cost an arm and a leg.Wow. Compared against my other vehicles, the S has the best headlights. Even better than the HID retrofit I did on the 4Runner with its projector housing (I know many just put HIDs in on reflector housings and those suck). I guess ignorance is bliss!
They ALWAYS say no retrofit but there is NO reason why the bumper cover couldn't be. There isn't much to the front bumper and the primary secure points are the same. (Remember the Model S door sills suposedly weren't retrofittable... and yet they are n my car.
I'll take pics when Ive completed it
The thing to remember with the LED lights is they are adaptive like the MX, so they will use a control line to tell them which way to point and perhaps a separate power line for the stepper motor. This definitely means a new wiring harness and perhaps a new connector. Depending on how the ballast is handled, that would be an additional complication.
So, can you hack your harness to power the lights? Sure, but you will likely compromise any warranty/ESA coverage you have and you are not going to get the adaptive function as the signal lines do not exist and the car is not going to know it should be pointing headlights even if they did.
Or just a prototype of the bumper while the headlights were still being worked on. That photo is taken inside the lobby of Tesla HQ in Palo Alto. There's another one where it's parked near the chargers in Tesla HQ's parking lot. Could have been a test to see how it looked.More likely a rare transitional car. Tesla has a history of producing a small amount of cars in between major changes. For example, a small number of non-autopilot cars have the autopilot style turn stalk.
No, just open the hood and then jump on the battery directly, no need for the jump post.How would you get to the jump posts on a car with a dead 12v? Would you remove the bumper cover to do that?
