No, and now we're back to my original post. Musk's stated Cd target for Model 3 is 0.21, which is 87,5% that of Model S, while it's a smaller vehicle, aka smaller cross section. So CdA is significantly smaller in Model 3, perhaps 75% (if 93% as long on each axis), maybe less (90% as long on each axis = 71% CdA; 87% as long on each axis = 66% CdA; etc). It's also likely hundreds of kilograms lighter (smaller pack, smaller footprint - despite using a mix of steel and aluminum), and if anything the tires look even lower Crr. And even parasitic draws should be lower (e.g. heating and cooling needs are proportional to surface area). The simple fact is, Model 3 - by its very design principles to minimize battery size/cost without making range unacceptable - uses less energy per km, aka gets more range per kWh of charging. If it uses, say, 67% as much energy per mile, then 48A adds 100 miles of range in exactly the same length of time as 72A on Model S. If it uses 75% as much energy, it's only a 12% difference. 80% energy consumption is a 20% difference.
