The issue is current (amps), not necessarily power (volts * amps) though they are related.Regarding a charge rate of greater than 120kW, what is the max power supported by the Tesla connector?
I would think its near its limit.
What is the max power supported by SAE DC connector and the CHAdeMO connector?
And they haven't built any 200A rated connectors because all the chargers thus far are 125A:CHAdeMO has similar theoretical limits to SAE DC, with the story confused by the fact that actual deployed connectors generally have a lower rating - this is largely because there's no point putting a 200A-rated connector on a 125A-max charger.
I would love to know this too, but only Tesla would know this. If some one is able to accurately measure the contact surface of the connector, it might be possible to guess. Also if anyone looks at the wiring for the power pins in side the car, it'll be possible to know the car's limit (although not necessarily the same as the connectors).Regarding a charge rate of greater than 120kW, what is the max power supported by the Tesla connector?
It should be relatively easy to built an adapter that allows a CHAdeMO vehicle charge off an SAE DC charger or Supercharger. The CHAdeMO socket has more pins than necessary. Just assign them accordingly.The latest CHAdeMO (I think 1.09 from memory) can do V2H. I doubt that they are sending payment processing, but I like that idea.
I wonder if they is a way to send the GreenPHY PLC over any of the existing CHAdeMO pins, and vice versa... send CAN messages via GreenPHY PLC to Tesla / Frankenplug.
If that could be worked out, the whole adapter thing disappears. You would only need a "pass through" physical adaptor to make any DC charger work.
SAE DC is specified at max 200A, max 500V (or 80A through the existing J1772 connector rather than the 'frankenplug'). But in a practical charging system you never achieve max current and max voltage at the same time, so the answer is not 100kW. For a Model S, the bulk of the fast charging occurs around 360V, so that would be around 72kW max through an SAE DC charger (or 29kW through an SAE DC with the smaller connector).
I put a couple phrases in red -- so this question is about the use of the "regular" J1772 connector with SAE DC.
Would this possibly work today using the existing Tesla J1772 adapter? While still slower than a 90kW Supercharger, being able to get 29kW DC would be a welcome speed improvement over a 30A / ~6kW J1772 public charger (or should I say 17A / ~3.3kW since Blink has derated their units due to overheating)... Would fully charge a 60kWh Model S in ~2 hours (yeah yeah, I know it will slow down for the last 10%)...
Obviously, you'd need to find a SAE DC charger with the regular J1772 adapter and not a CCS / Frankenplug...
Actually, it probably wouldn't need to slow down for the last 10%, as it's barely above what a HPWC on full bore (at 240V) can deliver.
ZBB,
It sounds like a good bit of work. You mention the Public J1772 chargers, and Blink; It's important to remember that those that have installed these chargers have chosen to put in 3/6 kW systems rather than just a 17-20kW system. These 17-20kW J1772 systems exist now without the trouble of developing a SAE DC system, or a conversion to the Tesla DC standard, but the US install base has chosen not to (for various reasons). A perfect example of a 20kW J1772 system is Tesla's own HPWC, and Sun Country's network in Canada. I've been lucky enough to use the Public 70-80A J1772's in Canada, and I think that simply rolling these out in the US would be the largest bang for the buck.
Peter
As arg points out there's that locking connector requirement, but also a small slot in the plastic of the adapter that makes it so the current adapter won't work:I put a couple phrases in red -- so this question is about the use of the "regular" J1772 connector with SAE DC.
That's a bit too handwavy for me. I don't buy the underlined assumption is straightforward. Who's to say the SC doesn't treat a low amperage request as a battery fault and refuses to do any charging at all? For example.To summarize - the car is in charge of how much power the car gets - the Spark EV simply tells the charger that it needs less current. So as long as you solve the mechanical and software communication, you should have no problem charging.
Because as others have stated, the SC is already capable of low current - it drops under 10 kW (less than 25A) at the end of a range charge.That's a bit too handwavy for me. I don't buy the underlined assumption is straightforward. Who's to say the SC doesn't treat a low amperage request as a battery fault and refuses to do any charging at all? For example.
Was just one example. Some people jump to "no problem" pretty quickly when it's often never easy and sometimes not possible. Heck, just getting reliable gennie charging for the Model S is a challenge. Talk to Roadster owners about how easy it is to get a SC working with their cars.Because as others have stated, the SC is already capable of low current - it drops under 10 kW (less than 25A) at the end of a range charge.
That's AC charging, not DC, and good quality generators that produce a good sine wave are not always easy to find. It's a common problem.Heck, just getting reliable gennie charging for the Model S is a challenge.
Huh? The Roadster isn't even capable of DC charging out of the box. That said, there are people who have modified their LEAF to accept additional high voltage DC (effectively DC QC by installing 1 or more chargers and injecting additional DC directly into the battery) and people who are reverse engineering CHAdeMO, so it should be possible to directly DC charge the Roadster with the right knowledge.Talk to Roadster owners about how easy it is to get a SC working with their cars.
Sigh. My point, again, is that very few things in live are easy or "just work" without some significant effort.That's AC charging, not DC, and good quality generators that produce a good sine wave are not always easy to find. It's a common problem.
I don't think that anyone is implying that it won't require significant knowledge of both the vehicle and the QC protocols involved...Sigh. My point, again, is that very few things in live are easy or "just work" without some significant effort.
Well the draft does say a transition period between now and 2018 (where dual connectors stations will be encouraged). So it's not going to happen immediately. IEC 62196-3 (which includes CCS) has its final release scheduled for December this year, so obviously there will not be CCS stations installed in the EU before then (outside of Germany, which already has adopted CCS independent of IEC).Note, any reports of the death of CHAdeMO here are grossly over-exagerated. There are now a couple of hundred sites installed or opening shortly in the UK alone and not one Combo charger.
Tesla would be daft not to include the CHAdeMO adapter here.
At least one MEP (Member of the European Parliament) has said that she will make sure any wording in this bill includes provision for CHAdeMO.
I don't think you understand how DC charging works. The roadster does not have a high voltage junction box. Unless someone redesigns a new PEM with a HV junction box, AND writes code to run that PEM, there will be no DC charging for roadsters. That is one expensive endeavor, since there were only 2500 cars produced.Huh? The Roadster isn't even capable of DC charging out of the box. That said, there are people who have modified their LEAF to accept additional high voltage DC (effectively DC QC by installing 1 or more chargers and injecting additional DC directly into the battery) and people who are reverse engineering CHAdeMO, so it should be possible to directly DC charge the Roadster with the right knowledge.
