Yes, I had a user (in this thread a few pages back I believe) show Scan My Tesla to Tesla to try to show his 12v battery draining, and have them fix it. They did some tests, and concluded it was the power draw of the bluetooth adapter that emptied the 12v battery. Then charged him for the troubleshooting and tests.
Story ends with him getting the car back, paying for the service, stopped using the app and adapter, then the week after, 12v battery died. Of course a few milliamps of a sleeping adapter (or even an operating one) does not affect this. But if you try to use the app against them, you can be sure they get defensive, blaming you for using 3rd party / non-original equipment. They always do with 3rd party stuff. I have my own experiences with this too:
- I was denied suspension troubleshooting, because I had 3rd party wheels. Came back on stock wheels, lo and behold they replaced all arms in my front suspension, because all bushings were worn out, and the car drove like *sugar* (Model S, just before warranty end at 100k km)
- had to pay for a new frunk actuator, it stopped working, and they blamed my 3rd party stiffer hood struts that opens all the way up. It was the 2nd latch, it doesn't know if you have stronger struts becuase it's the pop-up spring that contacts this latch in any case. Lost this case, couldn't get my car back without paying. (Model 3) Afterwards I read that this is a common problem on the Model 3's, and Tesla and many owners know this very well.
So whenever I go to their service center, more reluctantly each time, I make sure I remove all traces of obd2 adapters, wiring, apps or anything else that could look like I modified anything, just so I don't give them any excuse to get away from their warranty liabilities.
Unfortunately, their cars are so great that I have tried many times but always failed in finding anything else I want. And of course I need to keep at least 1 Tesla around to maintain the apps
.. hope the Cybertruck gets here soon, and that it comes to Norway at all. (And that I won't have to go to the service center at all
But to be serious, the customer service is frightening, and only getting worse. I think it's very strange they haven't been burned by the customers yet, enough for sales to drop and they losing money. I know quite a few people who had Teslas, got sick of the service and will never have a Tesla again.
Sorry for the rant and complete derailment, did not mean to kill your hopes about fixing your battery. But the fact is probably that a 60 mv voltage imbalance means nothing, if that module is failing you will just have to wait until it fails. Then of course you'll get a new (or refurbished) battery, as long as you are inside the 8 year drivetrain warranty period.
If that module has less capacity than the rest, it should go lower on voltage as you discharge, and go to 4.2 long before the others when charging. You can also have a look at the CAC numbers, these are not in the production version of Android yet unfortunately, but can be read from the Android beta version + IOS version.
Scan My Tesla should not be used 'against' Tesla for this reason, and for another reason: If Tesla feels the app is causing them trouble, they could probably do lots of things to shut it down, both technically but also legally. I hope that does not happen, so I like to encourage people not to use the app in that way. There are also disclaimers in the user agreements saying you can't use data from the app for this.
What you should use the app for, is educate yourself on how the car works, and if it is misbehaving, again use the app for education, then point out the fault using other sources, such as: If you get a replacement battery, and you suspect that battery has less capacity than your old battery, don't use the app, but rather record your range numbers from the car screen before and after. If you have a module that has less capacity than the others, this will also eventually show in the range numbers, but I suppose you can't demand a new battery until it has lost a significant amount of range.
Still, it shouldn't be like this, customers should have the right to read some of this data, to have some artillery in warranty disputes. Tesla sees the same data, but they won't show it to you. So Scan My Tesla is a great weapon, but like all weapons, it should be used with care and respect, together with a healthy morality compass. It was never intended to be used as a weapon, just as a curiosity satisfier.
