I read most of them but maybe it will save some folks who are late to the party from reading them all.
Didn't I read somewhere the reading of all 122 pages is a prerequisite for arbitration filing?
Hey, stop using my words against me!Going by the battery part number suffix, in this context, is meaningless.
Actually, I'm one rev earlier than you (1014114-00-E vs 1014114-00-F).FYI, "D" is no longer a sufficient answer - once they rev the part number, the number and letter suffix revert to "00-A"
In the early days, there was one main part number, so the letter was sufficient to identify a pack version. If you look at the degradation spreadsheet, we now have "1014114", "1074978", "1031043", "1088815", "1071941", "1107172", and who knows what else.
Your picture shows you have "1014114-00-D". You know that your battery is earlier than my "1014114-00-E", but you can't infer anything about ours in relation to another part number ("1074978-xx-y", for example).
Not really a good analogy. Porsche didn't push down a ECU update that added rev ranges, or changed the RPM limits after the fact (spoken as a 986/996 owner with the Durametric tools).Sorry you can’t buy a Porsche either as Porsche has done it to their cars.
Porsche Rev range activity guide | 911virgin
@FlatSix911 may have more info.
Tesla's response to owners on issues is like a fart nobody wants to be around when they come out.
Here is Jason's post where is states he pulled these numbers from the firmware.
Calculate usable battery capacity based on rated miles values
BTW, an ex Tesla employee said the buffer was not designed to be completely inaccessible. It was designed to be used (at least partially) should the BMS miscalculate and come in short towards the end. To prevent the car from shutting down before showing 0, it would allow you to drive into the buffer. I certainly did this a few times. Elon tweeted about this as well.
Would you elaborate on this?
Has there been a hacking incidence?
Tnx.
@sorka I doubt it, that just deletes user settings not the entire OS - depending on how they go about it that might even (yikes!) install the staged update (but I doubt it). There are tips around the forum to unplug your seat and try to install an update so the seat error makes it fail, and if you have enough failures it gives up and stops staging update. but I'm not brave enough to risk letting tesla take more of my car from me so I can't confirm this works.
No, but people forget that they tried that one app to connect with their car and then deleted it, but maybe the service is still polling the car.who knows. Just to be safe and remove possiblity of some other source polling the car.
Does anyone know if a factory reset will delete a staged (yellow clock) update?
Not likely. I searched out there and found only ONE random person that stated that if you set the update to start in 5 minutes and instead drive the car before it starts, it fails and has to re-download.Does anyone know if a factory reset will delete a staged (yellow clock) update?
I would say it’s heavy rather than excessive. Before the download, I would lose between 0.5% to 1% per night. It was because I was regularly losing 2% per night that drew my attention to the battery issue. The Vampire loss has increased, slowly, over time. It now seems to be steady at 4% per night (4% on 3 of the last 4 nights). But I have lost 14% over 4 nights, and 8% over 2 nights when I haven’t even driven the car!My daily loss while the car is parked in a ~80 degrees (F) garage and plugged in is 1.7%. Is that excessive in your opinion?
I find it interesting that Tesla claim the restriction on my battery is because they want to improve longevity and the health of my battery. Really? So they have reduced the capacity of my battery from 70kWh to 58 kWh. This means:here is an article I found and it sounds like the software update was because of the Tesla fires,
"As we continue our investigation of the root cause, out of an abundance of caution, we are revising charge and thermal management settings on Model S and Model X vehicles via an over-the-air software update that will begin rolling out today, to help further protect the battery and improve battery longevity.”
seems to me this update was due to the fires but just my opinion here is the article ,
Tesla is updating its battery software following a car fire, claims improve longevity - Electrek
Well... you still have a 70 kWh battery. It is just only charging to 83% of capacity (Good).I find it interesting that Tesla claim the restriction on my battery is because they want to improve longevity and the health of my battery. Really? So they have reduced the capacity of my battery from 70kWh to 58 kWh. This means:
1. I have to charge more frequently. Each journey takes 50% more energy than before. (Bad for the battery.)
2. I have to charge to a higher SoC (90%+) to regain some of the lost distance. (Bad)
3. Once charged the battery is likely to remain at a higher SoC for longer periods. (Bad)
4. There is a ratio between the charging power and the battery capacity. Called C Rate. Li Ion batteries can survive without damage up to a C Rate of 2
Charging a 70kWh battery on 120 kW Supercharger equals C Rate of 1.7 (Good)
Charging a 58kWh battery on 120 kW Supercharger equals C Rate of 2.08 (Bad)
So it seems that Teslas interference with my battery, to make it healthier and live longer, seems to have now put it in a regime that is worse for its health and longevity in the four main areas.
