I agree 100%, I was chastised by members on this board for comparing this to dieselgate. Look where we are now.
I think it was just your avatar freaking them out. But we've grown used to it.
Perhaps it should be all cars that have the same, old style battery, ie exclude M3.Or looking at it another way - current Tesla UK registrations total ~12,700 of which ~2650 are 70's & 85's = about 20% of the fleet.
20% of 5000 members = 1000 of which 20 report range loss = 2% - similar to the 2.25% figure above. Then multiply up to account for inactive/non-responsive members...
clean the dust pleaseTo repeat some point I made weeks ago and to further the case that we are not dealing with degradation but battery capping at the top:
I get great REGEN even at 100% indicated range which would be in violation of the BMS in previous software and make the battery go bad quickly.
(Tesla went the Audi Etron route)
I get the limit even when warm when there is 120-130 rated miles or less. I see it only during acceleration when I hit the top, it throttles back. Already took it in. They said it is normal as usualThe voltage limit directly lowers performance and reduces how much it can provide. It's a solid hypothesis. I drive my car above 400 wh/m every day, you don't. Everyone else please weigh in - Tesla won't supply the data but we all can.
BTW you should not be seeing the yellow line on acceleration unless it is extremely cold and your battery is frozen, or your state of charge is very low (20%?). If you're seeing it under normal summer driving conditions on a properly charged battery bring it in to be fixed.
When I first noticed this thread in May and started for the first time to actively post on this forum, my assumption was I'm doing so because I'm impacted by the update and would like to see what other impacted owners would have to say.
Which is why they clearly disclose that the range number is the EPA range for new vehicles and vehicle range depends on battery age and condition.
Lucky you. I got slapped down to 215 from 259 all at once in one charge sessionMy car is still capped 5 miles at full charge and has a current mileage of 249 @100%. Current software of 2019.28.2. Before capping it was 254 miles.
I was capped down 17 miles before update 2019.28.2. I hope yours goes in a better direction too!Lucky you. I got slapped down to 215 from 259 all at once in one charge session![]()
If it were a bug, I think Tesla would have said as much. In my experience Tesla service has no problem admitting to bugs.Makes no sense for Tesla to deliberately hobble their flagship vehicles. Much more likely this is a poorly thought out bug fix that introduced even worse bugs.
Are you basing this on the original 310 miles or the updated 325 miles?I know this is the model S forum but I've seen a downward trend ever since 2019.16.x on my Model 3. Went from 0% degradation (at 21k miles) to 6.8% right now (at 28k miles). I posted to a Canadian Facebook forum and a lot of other are seeing the same thing since around June timeframe.
It’s not a bug. It’s deliberate.
Not complete yet but enough data to publish. This a static voltage vs SOC chart. The blue series is the SOC as displayed in TM-SPY which includes 4 kWh that the IC/MCU display excludes. So as the charge drops, these diverge. At the lost point that I have data for, TM-SPY displayed 21.2% and the car displayed 17%. They merge when you hit 100%. It's also important to note this is based on a battery that has 74.4 kWh down from an original 77.8. This is car that has NOT been software limited in capacity.
I will add more as I get it. There's not much above 90% because I rarely charge above that. I charged once to 100% on my recent long trip as it was necessary. The trip would have been impossible to make had I had v9 and had been limited as much as some of the others here.
There would have been a couple of data points below 17% but I spaced as I was more concerned with just getting the car on the charger. You can almost see the start of the rapid decline on the low end. The discharge curve would curve down quite vertically as it approaches 3 volts. Hopefully I can make a point to get it that low in the next week or so.
Was the voltage while 'resting' or while charging?
